2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2007 Navigator power loss at mid rpm
Old 02-21-2012, 04:51 PM
twgreenwood's Avatar
twgreenwood
twgreenwood is offline
My 2007 Navi has been a good truck and given me 137,000 miles, but I am having trouble solving a power loss issue between 3000 and 4000 rpm. Engine runs smooth and strong right up to 3000 rpms or so. Then the engine feels like it is struggling to get air(or enough fuel) and the power falls way off. If I let the rpms come back down under 3000, the truck continues to accelerate strongly with no missing. If i hold it in gear to push it into the 4000+ rpm range, power returns. Between 3- 4k, the engine coughs, sputters, hesitates big time and misfires. I can't get the cel to come on so I can get a code. It has all new coils, new fuel filter and new MAF. Any ideas on this issue are appreciated!
Old 02-22-2012, 10:58 AM
TFWcustoms's Avatar
TFWcustoms
TFWcustoms is offline
Have the spark plugs ever been replaced? Also what type of fuel are you putting it, maybe its hitting the knock sensor? Last thing I can think of is the timing
Old 02-22-2012, 11:26 AM
twgreenwood
Plugs were changed at 97,000, using 87 octane, and at 110,000 the timing sprocket and chain were replaced. I don't drive the truck hard, so I don't really know when this issue started. I've been reading up on problems at 3000 rpm....could it be an intake manifold tuning valve issue?
Old 02-25-2012, 12:55 PM
Boomer1956's Avatar
Boomer1956
Boomer1956 is offline
Just asking, what tonage of a trailer are you towing to get the RPM's over 3K. I have a 07 EL Limited and with six adults I have never been in the 3K plus, range of RPM's.
Old 02-25-2012, 02:02 PM
chuck s's Avatar
chuck s
chuck s is offline
I can get mine over 3000 rpms dusting off those new Camero's at traffic lights...
-- Chuck
Old 02-26-2012, 12:02 PM
twgreenwood
It only gets above 3000 rpms when I am merging onto the freeway or passing and have to mash the gas. It is not that it can't be driven effectively now, I just want to be able to pass and accelerate quickly if needed.
Old 02-27-2012, 11:27 AM
kennisonxgs's Avatar
kennisonxgs
kennisonxgs is offline
I wonder if the a spark plug is loose. I had a similar experience with one of my older vehicles, and that's the same symptom it exhibited when one of the plugs was loose.
Old 02-27-2012, 12:55 PM
maverick1701's Avatar
maverick1701
maverick1701 is offline
what about fuel filters? (although as Im saying this...I do realize the motor smooths out at higher RPMs after the rough range)
Old 02-27-2012, 08:18 PM
twgreenwood
I decided to go ahead and get a SCT flash programming tuner for the PCM. Looking at it on the dyno, the technician was able to see what was happening between 3-4000 rpms and made tweaks to limit the low value for spark timing in the mid rpms and adjustments in air/fuel mixture. Now the truck runs great and accelerates through the whole powerband effectively. It's like I have a new truck. Nice.... I'll run a few tanks of gas through to see where gas mileage ended up. I was getting 13.7 mpg before the tune.
Jimmy Pet
Modular V10 (6.8l)
127
08-04-2019 01:21 PM
Jayme Duty
07-28-2011 09:43 PM
CNC
1999 to 2016 Super Duty
01-24-2010 04:29 PM
KYFord
1983 - 2012 Ranger & B-Series
06-22-2004 11:42 PM
bgnarley
1997-2006 Expedition & Navigator
03-21-2004 02:20 AM
Quick Reply: 2007 Navigator power loss at mid rpm
