1981 ford f100 question
Old 03-25-2012, 10:32 PM
Matt Rearden's Avatar
Matt Rearden
Matt Rearden is offline
truck was sitting for ehh i say 5 months my old carb got a crack in it where the fuel filter went.upgraded to a new intake and 4 barrel carb.but befor i replaced the carb it switched into reverse perfectly now it kinda squeals when i put it in reverse.
  #62
Old 03-25-2012, 10:38 PM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
You had to change the kick down linkage when you put the new carb on. I've read that the AOD is super critical to how that is adjusted. What proceedure did you use to adjust it?
  #63
Old 03-25-2012, 10:39 PM
Matt Rearden
i havent changed any linkage still has the stock kickdown tubular one.
  #64
Old 03-25-2012, 11:04 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
  #65
Old 03-26-2012, 02:53 AM
bruno2's Avatar
bruno2
bruno2 is offline
Well from what I understand the AOD has a TV cable and not a tubular kickdown rod. If it has the tubular kickdown rod it may be a C6.
  #66
Old 03-26-2012, 05:40 AM
Old Hickory's Avatar
Old Hickory
Old Hickory is offline
1981 F100s with the AOD all had tubular TV rods that look very similar to the C4&C6
kickdown rods but perform a much different function. As said before, if it is an AOD
get someone knowledgeable about AODs to help get the TV hookup right.
If you fail to hook it up and adjust it correctly you will destroy the AOD in short order.
  #67
Old 03-26-2012, 09:36 AM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Matt - Here's what the '81 FSM says about auto transmissions in general, including the AOD, with regard to your symptom:
No drive, slips or chatters in reverse - forward OK:
  • Improper fluid level
  • Damaged or improperly adjusted linkage
  • Looseness in the driveshaft, u-joints or engine mounts
  • Reverse bands out of adjustment or damaged reverse clutches
  • Improper oil pressure control
  • Damaged or worn reverse clutch or servo
  • Valve body loose
  • Dirty or sticking valve body
And, here's what it says about adjusting the TV Control Linkage, with the bolding from Ford:
  1. Check that the engine idle speed is set at specifications.
  2. De-cam the fast idle cam on the carb so that the throttle lever is at its idle stop. Place shift lever in N (Neutral), set park brake. (Engine off.)
  3. Backout (CCW) linkage lever adjusting screw all the way (screw end flush with lever face)
  4. Turn in (CW) linkage lever adjusting screw until a thin shim (.005 max) or a piece of writing paper fits snug between end of screw and Throttle Lever. To eliminate effect of friction, push Lindage Lever forward (tending to close gap) and release before checking clearance between end of screw and Throttle Lever. Do not apply any load on levers with tools or hands while checking gap.
  5. Turn in (CW) adjusting screw an additional four turns. (Four turns are preferred. Two turns minimum is permissible if screw travel is limited.)
  6. If it is not possible to turn in adjusting screw at least two additional turns or if there was insufficient screw adjusting capacity to obtain an initial gap in Step 2 above, refer to Linkage Adjustment at Transmission.
  #68
Old 12-05-2012, 12:12 AM
Old81F100Brown's Avatar
Old81F100Brown
Old81F100Brown is offline
Vacuum Diagram
This may be stupid. But the vacuum diagram should be right on the top where the hood latch is. Is it gone? I have an 1981 Ford F-100 302 3 speed with OD and I can take a picture of my vacuum diagram and post it?
Originally Posted by Gary Lewis
Then why do you need the vacuum diagram? You need vacuum into the cab for the HVAC controls, vacuum to the tranny if it is an auto, vacuum for the power brake booster, vacuum for the cruise control if you have one, and ported vacuum to the distributor.
The first 4 should come from a vacuum tree at the back of the intake manifold, and the ported vacuum is probably on the passenger's side of the primary metering plate on the carb, up high.
  #69
Old 12-05-2012, 04:34 AM
ctubutis's Avatar
ctubutis
ctubutis is offline
Here is mine for reference:
These things include engine controls only, not A/C or Speed Control or whatever.
NCook
03-06-2017 03:55 PM
SmallBlockV8
06-21-2010 06:50 PM
madrox
10-26-2009 01:04 AM
mandad62
08-19-2003 10:58 PM
Quick Reply: 1981 ford f100 question
