I Beam
on
I Beam
If you are using the poly bushings you must save your old shells. This means you need to have the old ones pressed out. If you are using a set from NAPA or some other supplier they will have new shells. Just beat out the old and carefully squeeze the new ones in using your vise or a 2x4 and hammer. I guess you could buy new bushings with the shells, cut out the rubber and stick the poly bushings in and install as above. I use the NAPA ones and just squeeze them in with my vice. I also assemble the spindles on the bench and then install the I-Beam and spindles already assembled. Makes it easier to get those thin shims in.
