1956 dome light
#32
Received 4,132 Likes
on
#33
#34
on
#35
Ill do some research. I have seen one in the $600 range but thats a bit much for the use I would get out of it. I really wonder what the guys do who have done this install. And I wonder how they were made on the production line. I had to cut them loose when I removed the stock sheet metal, so I know they were originally spot welded.
#36
When I replaced the top of my cab, I carefully bent the flange on the lower section down. Then I used a pneumatic hole punch on the top section, spaced the same as the original spot welds.
When the top was in place I plug welded the two together, making sure not to overheat the metal. Then I carefully bent the flange back up.
Sorry I don't have pictures. That was in the early 90s.
You could probably drill holes in the lower section and plug weld from the bottom. This would keep you from having to bend the flange down. The top section is difficult to get to with the flange in the way.
#37
#39
t_b0ne
04-20-2017 01:22 PM
56_big_window
11-28-2005 03:31 PM
