Gearheads Power Steering
Ooooh. Thats a link worth bookmarking! (Has stuff i can use for my '53 Ford cars)
Don't know how their steering conversion is set up. They sure don't post up many pics of their stuff. Someone else on here may have tried Gearheads' p/s kit on their truck. On my '56 I used a Toyota p/s box conversion. Its my understanding that this same Toyota box can be worked into the '48-'52 trucks. Mid-Fifty as well as CPP sell kits for the 53-56. I could have sworn someone used one of these kits on their pre-53 truck. Hopefully someone will chime in and give a little advice.
Integral Power Steering Gearbox Mounting Kit
for 1948-1952 Ford F100 or F250 Pickups
Convert your manual steering to integral power steering.
Easy to install, with no welding required.
The pitman arm is in the same location as your original pitman arm.
This kit uses all of your original steering linkage.
Works with your original straight axle front ends.
Works well with Gearheads power steering pump, brackets and pulley combinations.
Kit includes: pitman arm, mounting bracket and mounting hardware.
When available, we can also supply the power steering gearbox.
Also available: steering coupler; hose kit, with reusable ends; column clamp, to anchor the steering column to the firewall; and column tube bearing.
This item sells for $250.00, plus shipping.
Almost sound like a possible Toyota box swap? The really don't explain much or have many pics on the web site. Might be worth giving them a call and asking them what it all entails.
I went and looked at that link he posted @Gearheads. This is what they listed-
GEARHEADS EXCLUSIVE
GearheadDiva
13
12-17-2022 12:40 AM
wogden
12-11-2016 12:45 PM
BigBlueCat
13
08-15-2016 04:36 PM
53OlderThanMe
07-13-2013 10:38 PM
DillonZ81ford
02-12-2010 01:54 PM
