2001 f350 wheels
Old 02-22-2012, 08:44 AM
strokinpower350's Avatar
strokinpower350
strokinpower350 is offline
2001 f350 wheels
I want to fit 2007 f 350 dually rims on my 2001 f350 dually 4x4 powerstroke if this is possible what all would i need?, thanks
Old 02-22-2012, 09:30 AM
nlemerise's Avatar
nlemerise
nlemerise is offline
I don't think a direct fit is possible...2001 has an 8 - 170mm bolt pattern, 2007 has a 8 - 200mm pattern.
Old 02-22-2012, 09:45 AM
DemonRace6's Avatar
DemonRace6
DemonRace6 is offline
Hi!
I thought the only difference was the offset/backspacing? I put 2010 rims on my 2001, they fit the lug pattern but the front wheels rubbed real bad. I had a 2k foot turning radius...
Old 02-22-2012, 09:49 AM
strokinpower350
Yes that is what i thought so does that mean its not possible?
Old 02-22-2012, 10:30 AM
DemonRace6's Avatar
DemonRace6
Hi!
If Neal is correct and the bolt patter is different, no it is not possible. (well anything is possible but don't do it)
If the bolt pattern is the same then it is possible but you need wheel spacers.
Old 02-22-2012, 10:46 AM
strokinpower350
Is there 8-170 to 8-200 adapters
Old 02-22-2012, 11:24 AM
SARDiverDan's Avatar
SARDiverDan
SARDiverDan is online now
Yes, it’s called a power drill and a large drill bit but I would not recommend it. If the bolt patterns don’t match up then you have two choices, different wheels or converting your entire system over to match a 2007 configuration. Cheaper to just find a different wheel…
Old 02-22-2012, 12:03 PM
strokinpower350
Does anyone have pictures of a good dually wheel and i dont want 24"s i would like 16 to 18 inch black or chrome let me see what some people got
Old 02-22-2012, 12:10 PM
nlemerise's Avatar
nlemerise
I just tried tirerack.com wheel fitment...it says 2001 F350 dually 4x4 has 8-170 and 2007 F350 4x4 has 8 - 200. I could very well be wrong, it wouldn't be the first time and I know not the last.
Old 02-22-2012, 12:11 PM
nlemerise's Avatar
nlemerise
Go to tirerack...you can see the wheels on your truck.
Old 02-22-2012, 02:33 PM
strokinpower350
Tirerack only has 4 rims available what u guys got?
Old 02-22-2012, 02:45 PM
DemonRace6's Avatar
DemonRace6
Hi!
I would say Neal is correct then, and forget about the 2007 rims.
As far as wheel choices, check ebay for ideas, lots of wheels on there. I'm always shopping on ebay, damn PSM! (or is it PMS?)
Old 02-22-2012, 03:04 PM
strokinpower350
Ok thanks demonrace6
Old 02-22-2012, 07:44 PM
sloopdog1's Avatar
sloopdog1
sloopdog1 is offline
I thought that was the normal turning radius.
Old 02-23-2012, 11:11 AM
DemonRace6's Avatar
DemonRace6
Hi!
haha, yea its pretty bad, but that was worse. it looked good doing it tho!
Quick Reply: 2001 f350 wheels
