Ranger hates hills, almost no acceleration in 5th
Welcome to FTE. This is a great site for help with all things Ranger.
1. Your engine is an I-4 inline engine, not a "V" configuration.
2. The 4 cylinder Lima engine is not a powerhouse, but it should be able to easily maintain 65 mph on level ground. How many miles are on the truck? Where are you on routine maintenance, i.e., plugs & wires. What kind of fuel mileage do you get with the truck? Is the check engine light on? If so, take the truck to an auto parts store and have them read the codes. Write them down and post them here and we can help you out is getting better performance with your truck.
Let know what you find out.
I have a 93 with 200,000 on it 4cyl 5 speed and live in Pa so we have our share of hills. Sometime ago I was going North on the North east extension of the turnpike and I noticed the power was falling off. The first thing that came to mind was well if this was a diesel I'd be looking at a blocked fuel filter. When I got home I changed it what a differece. Yes you will have to use the transmission as It won't run to the top of the grade in 5th thats od. Mine will run along 70 75 mph. I think that the engineers did quite a job on this little 4 cylinder. kotzy
It's going on 300k, routine maintenance, plugs and wires checked when oil is replaced around every 2-3 months. Check engine light has been on, mechanic said it shouldn't be worried about, doesn't affect anything. I know it's got a hell a lot of miles on it and surprises me it's still running.
my 2.3 didnt like long upgrades even after a overhaul. its a great fuel-economy engine, but it does lack in tourque! id do a comprestoin check on it, if all 4 are withing 20 psi of each other and it has at least 100 psi, id look into the check engine light issue, it might make a difference.
boyd searer
1983 - 2012 Ranger & B-Series
10-30-2005 12:11 PM
CaRbOnFiBaH7
03-01-2004 08:35 PM
