Old B100 Smells Like Paint Thinner...Usable?
Old 01-01-2013, 11:55 AM
The Eddie's Avatar
The Eddie
The Eddie is offline
I burn store-bought (small indivdual business) B100 in my mechanical BTA-5.9 (when possible); I have since 2000.
Straight B100 sometimes, blended with petroldiesel at others, straight ULSD when I can't avoid it. I have nothing but praises for the stuff (overspills're kinda rough on the paint, tho...)
I was cleaning out my garage, and came across 3 five-gallon jerry cans full of B-?, probably B-100, that I fergot about; bought probably in 2006. It smells exactly like paint thinner; what happened chemically?
I haven't poured any into a clear glass yet to look at it, but what's your feeling--is this stuff usable? My gut tells me HECK NO STOOPID!...but 15 gallons is 15 gallons...
Eddie
Old 01-02-2013, 01:49 AM
joshofalltrades's Avatar
joshofalltrades
joshofalltrades is offline
i probably wouldn't run it by itself, but if you run it through a filter to catch anything funny that may have settled out, then pour one jerry can of it into a mostly full tank of fuel, i would expect it to blend in and be totally harmless.
i burn a mix of waste motor oil (WMO) in my 6.9, and the engine doesn't respond any differently no matter what i pour in it. some days the WMO smells of gasoline, other days of 90wt. but i don't run more than about 25% WMO, so being 75%+ pump fuel with a little of whatever else mixed in, its totally happy.
Old 01-02-2013, 12:18 PM
The Eddie's Avatar
The Eddie
Well, That's What I Wanted to Hear...
...now that you got me thinkin' 'bout it, kerosine/heating oil/real old Scotch (kidding) smells just like this "well-aged" B100, too.
Kerosine/heating oil is winter-time Diesel No. 1, right?
We're in the very coldest depths of "Winter" here in South Texas right now; it's a bitterly cold Arctic-like 56-degrees right now)--So I better get after it before "winter" ends tomorrow.
eddiE
Last edited by The Eddie; 01-02-2013 at 12:20 PM. Reason: Needed to add emphasis on how cold it...isn't
Old 01-02-2013, 11:48 PM
joshofalltrades
not exactly i don't think, but close counts on these things. you can burn darn near anything in an IDI.
and your 56 degrees of "cold" sounds like a mediocre day of SUMMER around here - i have a little snow on the ground and i'm guessing windchill puts us below 20, while actual temp is probably upper 20s at night and somewhere in the 30s for a high.
Old 01-24-2013, 10:52 PM
speedwrench72's Avatar
speedwrench72
speedwrench72 is offline
Jet fuel/ and JetA1 (winter Jet), clear evaporates,no resadue..is not kerosene,,/ stove oil,same as #1 diesel, same as kerosene, dyed when used as stove oil, for heating (no road tax),,..#2 diesel, dyed when used as furnace oil,or of road or farm use,
Old 01-24-2013, 11:03 PM
speedwrench72
More power,,(BTU) in B100 than #2 ,, but it thickins when cold..more BTU in WMO than #2,, same problem...First three rule's with WVO or WMO,.#1..Fillter,#2 Heat and Fillter,#3 Fillter more..Blend and repeat...
ryan f150 4x4
Paint & Bodywork
01-02-2010 10:09 AM
Sore Knuckles
Paint & Bodywork
08-04-2008 05:30 PM
Elderstarr
Paint & Bodywork
12-27-2006 06:48 PM
59flatbedford
Paint & Bodywork
07-19-2006 01:29 PM
Boss_358
Paint & Bodywork
10-25-2001 03:42 PM
Quick Reply: Old B100 Smells Like Paint Thinner...Usable?
