help id this trans?
help id this trans?
I am looking at this transmission for my 79 flareside. I am being told its out of a 78 f150. Not being a Ford expert and this is my first Ford I am quite inexperienced. I believe this to be a NP435 with a 205 transfer case. Would this be correct? Also I will be using this to replace my broke Borg Warner trans. Will the cross members be the same and the drive shaft yokes be the same?
Thanks in advance, I appreciate it!
New Process 435: The shift lever retainer cap (B8T-7220-D) has two notches, two pins that protrude from the tower retain it in place.
This cap must be pressed down and held down while turning it to remove it. Peeps are unaware, use pliers, tearing out one or both of the notches. Not pleasant!
Warner T-18: The shift lever retainer cap (8MTH-7220) is threaded, threads on/off. Once the cap is removed, there is a roll pin between the threads on the tower that retains the lever in place.
That's a good deal. I was looking for a 435 stamped somewhere. I have it soaking now. I shot them both with a bunch of gunk grease remover in hopes that it will make the trip to the car wash easier.
I plan on splitting the two apart to put them in the truck. I think that will be easier to handle. Before I do that should I put new gaskets or anything in them? They don't really look to be leaking just covered with a ton dirt.
Everything rotates easy and moves in and out of all the gears easy with no clunking so I am nit sure that I need to replace anything. I figures just cleaning them up really well and giving them a shot of paint.
Think that's ok? What should I look at before sticking them in there? Also right now I have a bourg waraner in there. Will I need to change the pressure plate or clutch? It should break an ok fit right? Unless its worn of course.
