Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
- How to Reset PCM Adaptive Memory
Step by step instructions for do-it-yourself repairs
fuel trim in computer
I just changed the spark plugs in my 2006 5.4L.A mechanic hooked his scan tool to my trucks computer before i changed the plugs.He told me that because my plugs were in such bad shape,the computer adjusted the fuel really rich.He said i should have the fuel trim put back to normal after i change the plugs.He said it takes the computer so long to lean the fuel back out,that it will end up with gas in the oil and that might wash out the bearings and cause major damage.Has anyone ever heard of such a thing?The truck runs absolutley perfect,doesn't smoke.
Disconnect the battery cable for 30 minutes, this wipes out the ECM's memory and it's just like firing up the engine for the 1st time.
IMHO...I think the mechanic is smoking something!
The mechanic is either an idiot or is clueless. Find a different one.
Fuel trims are stored in the PCM's Keep-Alive Memory (KAM) which resets automatically to factory defaults when the battery is disconnected, which usually only takes 5-10 minutes. Once the engine operation is restored, the PCM's adaptive learning strategy causes it to relearn the new optimal parameters for fuel mixture and transmission shifting, among other variables.
I see you are in Los Angeles...if on the west side, I can highly recommend Ed Little Auto Service...........family owned shop, been in business for 40+ years, same location, son has had the shop for 15 years now.....very, very honest. When I'm out of town and something goes wrong that needs attention, this is the shop my family takes the cars to.
The thing about Bob (the son) is if it is something that they can do, but the dealer can do it faster, better, etc, he will tell you that stright up. Also, if you need a dealer, I can also recommend SouthBay Ford in Hawthorne (Galpin too).....
I would avoid Airport Marina Ford/Honda like the black plague!
kev100
05-31-2003 07:05 PM
offroadguy
03-28-2003 03:16 PM
