98 Expedition Code P0304
I been having this code for the past couple of weeks, I took it to
my mechanic a week ago he replace the sprak plug on cyl#4 cause there was coolant leaking down into the cylinder. He fixed the coolant leak also by clampping down the hose that was leaking. I pick it up last Tuesday as soon as the truck warmed up, again the CEL light came on I pulled the code samething P0304. I turned around and took it back to my mechanic, He check it again the next day and said he gonna changed the coil pack on cyl#4. I went to pick it up last Friday, It drove good, I even droved it to work & back, I work 67miles from my house. Saturday I went to drive it as soon as it warmed up and I turned my heat on the CEL come on again. I pulled over check the code, Again P0304, What else can it be. Can it be the spark plug wire since coolant did leak down into cylinder#4. I puzzle here...
You can get an 8-pack of COPs off eBay for under $80 these days.
Well, must be you have a 4.6 then. If folks could put the model year and engine size in their sig line, alloro wouldn't have to try and guess what ignition system your '98 Expy has (although he usually guesses right ).
The 98 with the 4.6L motor uses coil packs. Each coil pack runs 4 cylinders and you will see spark plug wires. The 98 5.4L motor uses COPs, one per cylinder. Since you only had a misfire on one cylinder and your mechanic chose to replace the "coil pack" I made the leap that you just used the wrong terminology and do indeed have the 5.4L motor and 8 COPs.
