I get horrible mpgs and I am going to try a chip and see if it helps at all. I want a chip for economy but I would like a little more power too. Any suggestions
While your under the hood unplugging the ebpv, you should check all intake/turbo hoses make sure there are no boost leaks. Check your fuel filter to see if its clean. Also check your air filter.
Ya, don't expect big increases from a chip. You definitely have something wrong, fix it first like said. Exhaust leaks, boost leaks, fuel leaks, brakes dragging, etc. Lots of things to look at.
My mileage is 105 k now and I think the ebpv is stuck like another post suggested so I'll post once I figure out what effect that has. Thanks everyone for the help
