1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Installing overhead mgp console in 99 xl
Old 02-08-2012, 09:17 PM
krane operator's Avatar
krane operator
krane operator is offline
In the process of adding an overhead console with mpg to my super duty. I need to connect a wire for the "injector cycle duty", where can i find this? I pulled the pcm where it was supposed to be either pin 9 or pin 43 and there is nothing there. Thanks
__________________
Old 02-09-2012, 06:31 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
The 99 F250 does not have a wire that specifically carries an "injector duty cycle" signal to the PCM. You'd have to tap off one of the injector firing signal wires to get that.
PCM pin 9 is for the fuel gauge sender, pin 43 is the Data Output Link for the OHC, if equipped.
Old 02-09-2012, 06:53 AM
krane operator
Thanks sho for the response, u are very correct about that information, infact my truck being an xl it has no pin 9 nor 43. can u tell me which wire at the injector to tap ? thanks again sho.
Old 02-29-2012, 05:24 PM
krane operator
Update for mpg 2 door console install
Well the 2002 -2004 2 door console with mpg install is done in my 1999 f250 superduty 5.4 xl. This is not as complicated and expensive is it may sound. There is a guy by bird who sells these and it CAN get expensive , even 100 dollars for the wiring book for the mpg to work. I just went to wrekn yard and got a console with computer for 40 bucks and was able to cut off the harness conector that plugs into the console and made the rest of the harness . You can find all over the net how to cut the liner and wire the temp sender, but to wire the mpg computer into an xl, there is not a whole lot of info. There are 3 things required for mpg to work, speed sensor,fuel tank level sender, fuel flow. All these are at the pcm PINS, and not always in the harness. So i just unpluged pcm harness and drilled slot and added these wires into the plug harness and it is working. Here are the pin numbers for the 1999 5.4 superduty
At pcm on drivers side near fender well
pin 9 yellow/white wire = fuel tank sender
pin 58 gray/black wire = speed sensor(this is only wire that was in pcm harness)
pin43 orange/light green = data output link fuel flow
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 01-12-2014, 10:03 AM
TNScrambler's Avatar
TNScrambler
TNScrambler is offline
Sorry to bring up an old thread.... We are installing a console in a early 99 xl 7.3, we have pins 9,43, and 58 but we are unsure on the power source...the diagram we have says to pull from "iso bus 70" but we can't find that on any ecm pinouts.
Thanks!
Justin
Old 04-30-2019, 03:37 PM
Buckydun's Avatar
Buckydun
Buckydun is offline
Question I too have a 99 f250 super duty and am interested in installing the 2002-2004 overhead console. My question is will mounting tub fit the contour of the roof line or are any modifications involved. I understand that the metal roof pan already has the required pin receptacles just curious as all the sellers state they console won't fir the 99-01 model trucks
Old 05-02-2019, 08:10 PM
Brother Les's Avatar
Brother Les
Brother Les is offline
The '99 - '03 are all sister trucks style. I would assume that the that the overhead console that you are looking at would work fine. I have an '01 7.3 and have never seen a response from the 7.3 threads where the overhead consoles are not interchangeable.
Old 05-08-2019, 12:44 PM
Buckydun's Avatar
Buckydun
Buckydun is offline
Just an update. got the console installed a minor fitting problem but otherwise ok. The slots for the taps at the front were as stated in the correct places under the headliner and the tub snapped in place after trimming out the headliner. Problem is that the console shell is about two inches longer in the back that the slope of the headliner. This leaves a gap between the shell and the roof liner so I will have to figure out some kind of trim piece to fill it in. Wiring up the meter is next but overall satisfied and looks better than the hole in the headline that the previous owner left!
Russell2004
04-01-2016 02:28 AM
KevinPC13
09-12-2015 01:42 AM
njneer1
11-22-2011 01:00 PM
TXtinct
10-04-2011 08:50 AM
gregtx
09-09-2008 05:42 PM
Quick Reply: Installing overhead mgp console in 99 xl
