Is there such thing as a 2nd gear sensor in this truck?
on
Hi all, my neighbor is getting a 1994 Ford F250 4x4 351 auto transmission and the transmission shifts hard from 1st to 2nd. Well, the owners are saying that there is a bad 2nd gear sensor in it. I have never heard of such a thing. Also if there is such a thing how much work is it to fix it up? Should he just get it and figure it out from there.
Trav
Trav
That would be an E4OD most likely.. I'm not aware of a second gear sensor, but it is totally electronic controlled so it might be a solenoid. He needs to check for DTC codes in any event, because any engine code can aslo cause problems with the E4OD.
Just about any code will cause the E4OD to go into limp mode, and that causes hard shifts among other things.
on
Trav
on
Trav
White Light
05-16-2019 07:11 AM
Jrock909
08-07-2004 12:00 AM
guitar_god2003
02-22-2003 09:11 PM
