Turbo or fan? Cold starts
I've been noticing on cold mornings when I remote start the truck as soon as it cranks and fires theres a "spooling up" sound like the truck is about to take off. I haven't timed it but the only times I have noticed it is when I am loading up the truck, if I start it several minutes before I run out the door I don't hear it. It isn't the same noise Tom reported. My guess is probably a fan, but the turbo isn't out of the question either. If it is a fan, why the heck would it be starting up when things are ice cold?
on
I always said it was the turbo warmup sequence. If it was a fan it would not be that high pitched, and the fan on the 6.7L has an electronically controlled clutch from what I've read. A mechanically clutched fan will rev up with the engine at startup and it's louder.
If the cooling fan was going at turbo-speeds (to create a high frequency close to 10kHz like that) I'd be fearing flying fan blades... these are plastic blades.
I have good info for ya. In addition to what Tom says about the fan providing load and making heat, the turbo does spool in a cycle. It will run through some sort of procedure spooling up and down.
I know this because I have the AFE intake which removes the stock air filter box and also the tube, the AFE air tube is just a straight pipe with none of the baffles like the stock intake. Therefore, my engine and turbo are noticeably louder and I can hear the turbo doing all kinds of things much easier than those in stock form.
It's actually pretty neat and I like it a lot. If I think of it I would record the sound but I've never posted a vid or anything like that. Do I have to make a you tube account? Gonna take some time.....
caleb6.9
10-03-2010 01:32 PM
