NEWBIE TO F1 RESTO
#46
cdichiar
This is a newbie intervention......
With all honor and respect - 'cause you seem as dumb as me - don't be dreaming of parts swaps and big changes. Start with what you know and can accomplish.
Get it running. It is much cheaper to scrounge or buy a few replacement parts than wade directly into the frame off project land. It is also highly educational. You'll get to fix the brakes - a fairly straight forward proposition if you know how, or have a buddy with a couple of tools and a willingness to coach you. You'll also want to clean the gas tank and fuel lines. Putting clean gas into a rusty tank = rusty gas and no worky.
If the electrical is functional - didn't see any turn signals - you might be able to run it enough to get a sense of the other stuff to do. These old beauties are like a lot of people and equipment. If you live with them for a while, you understand them much better and know what needs to be done.
Enjoy.
DW
Enjoy.
DW
You haven't told us anything about what type of work space and equipment you have and/or what experience your dad has and how much help he is planning to add beside just money?
Most of us have been thru what you are entering into, we are not trying to discourage you, just trying to save you from what we learned the hard way. You are lucky, you have the internet to connect with dozens of other experienced enthusiasts that are willing to help and advise you, most of us started in a void and had to learn everything by trial and error. I started at your age, but computers were only a scientific dream, Mig welders were 10's of thousands of dollars and there were hardly any aftermarket suppliers.
#47
Really good advice. There is plenty of work that can/should be done without jumping into the deep end before you have learned to swim. You can always blow it completely apart later, but meanwhile you can find out if this hobby is really for you. Right now you cannot really even imagine just how much work, time and devotion just the basics will require, and you are just starting your adult life, there is going to be other interests in your life that will interfere and the build will interfere with: girls, dating, high school, college, working, friends, sports, etc, etc, etc. Just getting it running and drivable is going to take at least a couple years of most all your spare time. Save yourself a lot of frustration (and your dad a lot of money), learn to walk one step at a time, not by trying to enter a marathon race right out of the gate. Does you school offer auto mechanics, welding classes? How about community colleges or adult ed classes?
#49
#51
#52
#53
Hey Chris,
Here is what you are looking for - this pic is of the 8.8 inch axle & springs out of a 2001 Explorer - other years work also. Mine came with a 3.73 rear gear ratio - I think that might be a bit "tall" for a flathead - you'd get highway speed but lose a lot of low end uumph. Wait for experts to answer this one. Don't worry about the look of the axle - they clean up
just fine.
The 8.8 axle path brings a few challenges:
o The Wheel bolt pattern will change so unless you change the front axle you will be running different pattern of wheels on front & back - spare tire challenging.
o You will have to move the shock mounts to a new location once you
mount your 8.8 axle. (Grind off old ones & re-weld in a new location).
o We also flipped the springs in the back to give it a bit lower stance.
o You will now have an Explorer rear end & springs under your bed -
it will still hold cargo - it just rides a bit softer than the original suspension. (You go from an 8 spring pack to 3 springs).
o You will need to change your Brake set up a bit to accomodate rear
disc brakes. I changed to a Dual chamber master cylinder from a 70's mustang & you will have to add in a residual valve to accomodate drums in front & discs in back.
o If you don't already have an Emergency Brake the Explorer one fits our truck s pretty well. See if you can't get one of those from the same Explorer donor.
Good luck over there.
Ben in Austin
just fine.
Ben in Austin
