has anyone replaced the bushings for the upper control arms?
is it worth the effort?
No, it's not. New Moog control arms will come with new bushings and ball joints with grease zerks.
If I may, I'll pass on a recommendation. Before I began my truck's ball joint replacement last summer, I called the alignment shop and asked them for any tips. They requested I replace the original factory cam bolts that attached the upper control arms to the frame with a Moog adjustable cam bolt set. I did as they requested and received their thanks in return. Made their job a whole lot easier.
