Got a NP435 for a swap
Bullit390, as far as lifting the trans you have to realize Manfred is like 6'4'' and 200lbs.
Manfred, get the parts and bring it by the shop if ya want a little help rebuilding/installing. I think we can fit your truck in the shop no problem.... it'd be a LOT easier installing it in there, ya know.
so the real questions...
Did you get:
1. Shifter and boot
2. Clutch/Pressure plate et el
3. Pedal assembly and Zbar
I couldn't load the pictures, our signal stinks out here. I think I get back on land around Feb 23rd or something.
later
Drew
Did you get:
1. Shifter and boot
later
Drew
The M5OD I recently snagged for my Ranger is a breeze compared to those two!
Josh
you will need to shorten your front driveshaft and lengthen the rear or find a a set out of a manual trans 4wd truck.
I've got a 78 F150 with a 4spd. I'm willing to sell the pedal assembly and all the clutch linkage. The only thing is it's got a 300 inline 6 so I don't know if the Z-bar will work for your swap or not. I'm not sure if they had different width Z-bars for the different engines. But if you want any of my parts shoot me a PM and we can work out a deal.
#28
#29
Looks fine to me... Definately get some new plastic pads for the forks though.
I am going thru replacing the FM145 in my Ranger with a newer M5OD. The tranny was howling like a banshee, but I pulled the cover yesterday and it looks pristine that POS.
If you really want a rebuild just get a bearing and gasket kit and if your nervous about it find a replacement gear. Maybe add synchro rings, but the rest looks good.
Josh
Josh
