Front diff, do you hafta pull both axles?
I am changing my front differential (ratio) and the book says to take apart both side wheel ends and pull out the axles. I took the left side apart and pulled the C-clip and slide off the carrier assembly without taking the right wheel end apart. Now I am in the cleaning stage.
Has anyone try this short cut and did it work?
I am not looking forward to putting it back up there with the permetex drying away.
dont bother putting the C-clip back in either. run a 1" spring with some decent stiffness. not valve spring stiff though. this will give plenty of pressure and keep the axles in place. also makes trail repairs easier.
I would also install 4 Studs into the housing/thirdmember. this will make installing it much easier and less likely to have the RTV getting messed up. as for pulling both sides, I did and replaced the ujoints since i didnt want to get back in there
Stupid question time. Have people had problems with the valve spring? I have a stock Chevy 350 valve spring in my stub shaft and wondering if it's going to cause a problem.
We put the spring in the passenger side slip shaft.. Circled in this pic..
Pic of slip shaft with a Chevy 350 valve spring. Take Kemicalburns advice, don't use a valve spring if people have had problems with it. I was unaware that it isn't right for the job. I'll get a new spring and keep it in the glove box incase I have problems on the trail. LOL
Before you can do this though, you have to pull the u-joint out and weld the end cap in place so the spring and outer shaft doesn't push the cap out.. Here's a pic of that.
Cool deal. You had me worried! LOL I'll still keep an extra in the glove box just in case, but I think it'll be good. I had to push the outer shaft in pretty good to get it in. That was kinda a PITA.
I would also recommend to the OP to install some spicer 760x ujoints in the front axles. if you have access to additional grease be sure to repack the caps as ive noticed most ujoints these days are running a little shy in that department. then after the joints are installed in the axle put a couple minor tac welds on the cap/yolk. this will help keep everything from blowing out on you on the trail. unless of course your really flogging the dog with tires larger then 35's and locked up.
