Passenger side is dead
My buddy has a 02 that all of the sudden had hard start and a very rough idle.
He put a laser temp reader on the exhaust manifolds and the passenger side did not get hot. He lives off a dirt road, so I told him most likely a VCH plug came loose and to change them out. Well he did that today and it did not fix the issue. Any ideas what to look at next?
Thanks
Thanks
Here is a decent write up for testing IDM and injectors.
GB_Tech_Bulletin_103_Ford IDM_Module_Replacement (1).pdf
The IDM is located inside the DS fender behind the F250/F350 badge. Here is a picture without the fender, you do not need to remove the fender just the wheel well.
same problem with my truck, except driver's side Under valve Cover Harness(UVCH) inner plug went bad. replaced with new gasket and innder wiring harness, cost about $100
truck started and has been running perfectly! This is the most common and not too expensive to fix!
Attachment 47977
Attachment 47978
Attachment 47977
Attachment 47978
We Ran this test and with no luck, everything passed at arounf 2.8 Ohms
any other ideas guys??
