whats the normal trans temp 4r100?
Old 01-24-2012, 10:18 PM
2002exPSD's Avatar
2002exPSD
2002exPSD is offline
i can read the trans temp with the new programmer and ive noticed while driving both hiway and city my trans temps are between 190-200 not towing. ambient temp between 60-70. is this normal? i read somewhere that it should be about 80 above ambient.
Old 01-24-2012, 10:29 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Not towing, depending on weather and traffic conditions, 80 - 100 over ambient is normal, IIRC.
Search for posts by Mark Kovalski to make sure.
Stewart
Old 01-24-2012, 10:44 PM
ExxWhy's Avatar
ExxWhy
ExxWhy is offline
Received 2,109 Likes on 560 Posts
Mine runs 60 over not towing and 90-100 over ambient towing FWIW. Stock V10, no extra cooler.
Old 01-24-2012, 10:58 PM
Sunline Fan's Avatar
Sunline Fan
Sunline Fan is offline
Excursion Fleet Manager
Stock trans V10:
120-150 running on the highway solo all year long. Upper end of that range if the temps are really warm out, lower end when they are below 60ish outside.
City driving sometimes makes it jump more than that, but I haven't watched city enough to notice real ranges. 99% of the time it doesn't make it to full temp anyway because I don't go that far in 'city'.
Towing, ranges from 185-200, sometimes more, in the summer (only time I pull the TT). If it starts getting close to 210, I back down until it backs down.
FYI, in case you haven't noticed, your torque converter won't lock until the trans reaches 53 degrees, which is the start of the inner range on the dash gauge.
I have no experience with the 7.3 yet, but from the 6.4 at least, the trans temps run warmer the majority of the time. Not sure if that's just due to the Torqshift though. They hover more just under 200 solo and towing.
Old 01-24-2012, 11:52 PM
white Buffalo's Avatar
white Buffalo
white Buffalo is offline
You should see approx 70 degrees above OAT, that is driving unloaded. Around town it can go higher since the torque converter is unlock until @ 35 mph and generates more heat. You should be seeing temps around the 140-150 mark at those speeds. I see it go up to 80 degrees above OAT when driving above 80 mph or if the wind is a tailwind and the airflow across the tranny cooler is affected. I would start by dropping the pan and see if you have any debris in the pan.
Old 01-25-2012, 08:05 AM
TXSailor's Avatar
TXSailor
TXSailor is offline
Mine is 75 degrees OAT w/ no towing. Typically runs around 135 - 150 in normal city driving year round (but then in South TX temps are mild - most of the time).
Towing it will jump to 100 to 125 OAT depending upon terrain/season. I do have a 6.0 Trans cooler on it however JIC.
D
Old 01-25-2012, 09:12 AM
2002exPSD's Avatar
2002exPSD
Well it seems like my temps are too high. Guess I'll upgrade the cooler to one with an auto fan on it.
Old 01-25-2012, 09:23 AM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Retired Mod
D
Same here, I also have a 26 row 6.0 trans cooler....
Even in the 400 degree heat in Houston last summer, I rarely broke 150...
Hooking up a trailer to tow a car this weekend, I'll post back what temps are...
Old 01-25-2012, 10:08 AM
Rushmore X's Avatar
Rushmore X
Rushmore X is offline
I think I got mine up to 147 pulling the boat up to the lake w/ the AC on this summer. The 6.0 cooler is the bomb...
Old 01-25-2012, 12:17 PM
2002exPSD's Avatar
2002exPSD
I was thinking of getting something like this.
BD-Power Auxiliary Transmission Cooler Ford/GM
Old 01-25-2012, 12:18 PM
2002exPSD's Avatar
2002exPSD
When it's raining and 60 outside my max temp today was 140. I think that's a normal temp.
Old 01-25-2012, 12:30 PM
white Buffalo
That is normal and 50-60 degrees cooler than posted above. Do you have a custom bumper, cattle guard or something that is blocking the flow of air to the tranny cooler causing the higher temps when not raining?
Old 01-25-2012, 12:36 PM
2002exPSD's Avatar
2002exPSD
No nothing in the way. Stock bumper
Old 01-25-2012, 01:40 PM
Stewart_H's Avatar
Stewart_H
You can find a 6.0L trans cooler for cheaper than that.
Stewart
Old 01-25-2012, 02:46 PM
2002exPSD's Avatar
2002exPSD
Right but the other cooler is bigger and has a fan.
Quick Reply: whats the normal trans temp 4r100?
