XL to lariat conversion???
Umm... Do you want just the lariat look or the lariat functionality? Either way its VERY expensive to do yourself.
well i mean i want to convert my windows to power and the door locks, plus put in a tilt stearing wheel. I really want the leather interior, but i only need the driver and passenger seat and center consol. Ive been looking on ebay for interior components, and there ALOT to choose from. Installing it all i may bring my truck to my buddys diesel shop, hes good with fords. I just was interested if anyone else has taken on this task. Ill take pics as i go!!
Anything is possible with enough $$ and time. The trick would be a good source of parts that you can allocate for the entire conversion. I assume that all these trucks have the provisions to plug in the missing harnesses and so forth but I don't know that for certain. Good luck and keep us posted on your progress. I'm sure there are others that would like to see this.
i think you would have to have the wire harness's and pcm to make it work. plus the door panels and to get the harness out of the dash is a pain to do. would take more than a weekend job.
mine is a XLT and all it is missing from the Lariat is over head readout, 6-CD stereo, auto AC, fog lights, leather seat, and i hate leather seats.
i think what im going to do is just get lariat leather seats and center consol, leather is really the only thing i want haha. I have a bench seat now and it is the most uncomfortable thing in the world.
When getting the lariat leather seats with the heat option. Is there any wires that hook up through the floor? or is the components under the chair its self, all that i need??
I have an E99 XL that I've converted to XLT with the help of a donor 99 Lariat wiring harness, GEM Module, and fuse blocks. It now has power locks, windows, mirrors, cab light wiring (haven't the guts to drill in my roof yet to install the lights). This was a very very involved project and I suggest anyone doing this be a very committed person with a great deal of patience. It will certainly take more than a week of work to get this done.
The key to this which I've already seen stated here is that the donor truck must have all of the options your end product truck will have. For example: Early 1999 F350, 2wd, automatic, 4 wheel abs, crew cab, 7.3L, power windows, locks, mirrors, power seats, overhead console, cab lights, same tow package, auto headlamps, DRL's, driver's side air bag only, etc. If not, then at least get one from a truck with additional options you won't end up with rather than one that didn't have an option you are wanting to add. I would get all sensors, relays, engine compartment wiring, possibly the chasis wiring, and plug in modules from the donor truck if possible also.
You MUST have the GEM module re-programmed once you have it all in there too. If you decide you don't want DRL's or auto headlamps or the donor tuck was 4wd and yours is 2wd, that can all be fixed with the GEM module re-programming. An important note here is that you need to have the VIN # from the donor truck for the GEM re-programming to be accomplished. If not, you will have to hunt down a truck that had all of the options of the donor truck and plug that VIN# in.
Good luck if you decide to do this!
Drake
Drake
