The TJBEGGS E fuel thread! ALMOST COMPELTE!
#121
Interesting. My pump is alongside the frame rail, I think about where everyone else puts theirs and it primes just fine in a matter of seconds. The pump is below the normal fuel level in the tank (unless the tank level is pretty low) so it should have some positive suction head on it. When I first installed the efuel system someone told me that I didn't need a shutoff valve between the tank selector valve and the pre-filter. When I changed filters the first time a steady stream of fuel drained out so I had to install a shutoff valve.
Maybe if you run out of fuel and just add a gallon or so to get going again, the tank level is below the pump inlet and won't gravity feed the pump.
#124
#126
You need one of these: Hand Priming Pump
I used this only because I have it kicking around and used it to empty my rear tank when I did the swap and to transfer the fuel from the front tank to the rear tank when it started leaking.
Home Hardware
Last edited by nateairman; 12-16-2016 at 11:25 AM. Reason: Manual correcting auto correct
John Boyd
20
05-04-2006 06:30 PM
