1965-72 f100 shortbed frames the same?
Old 01-18-2012, 06:35 PM
lefty rodan's Avatar
lefty rodan
lefty rodan is offline
I'm looking for a better frame for my 1965 f100 2wd shortbed project. I seem to remember it being mentioned here that that the frames from 1965 through 1972 all interchange? If so does that mean the sheetmetal mounting points were the same for all these years? I tried the search section but could'nt find an answer. If they are the same that really expands my possibilities.
Looking for a frame or "non restorable" truck in the Mid Atlantic area. Thanks in advance for your help. Lefty
Old 01-18-2012, 08:25 PM
66f-100's Avatar
66f-100
66f-100 is offline
You might check with Tom at Flashback F100's located in NC. He saves all the frames from the trucks he parts out.
Flashback F100's - Home
Old 01-18-2012, 09:23 PM
Bill W's Avatar
Bill W
Bill W is offline
dont forget.... it will need a title. thats where the VIN is stamped.
Old 01-18-2012, 11:19 PM
camperspecial65's Avatar
camperspecial65
camperspecial65 is offline
They arent the same..different wheelbases...
- cs65
Old 01-19-2012, 01:46 AM
37 Ford guy's Avatar
37 Ford guy
37 Ford guy is offline
- cs65
This shows the '65 F100 shortbed at 115" 1965 FORD F100 Information Specifications Resources Pictures
'66 F100 shortbed at 115" 1966 FORD F100 Information Specifications Resources Pictures
'67 F100 shortbed at 115" 1967 FORD F100 Information Specifications Resources Pictures
'68 F100 shorbed at 115" 1968 FORD F100 Information Specifications Resources Pictures
'69 F100 shortbed at 115" 1969 FORD F100 Information Specifications Resources Pictures
'70 F100 shortbed at 115" 1970 FORD F100 Information Specifications Resources Pictures
'71 F100 shortbed at 115" 1971 FORD F100 Information Specifications Resources Pictures
'72 F100 shortbed at 115: 1972 FORD F100 Information Specifications Resources Pictures
'73 F100 shortbed at 117" 1973 FORD F100 Information Specifications Resources Pictures
Looks to me like they are the same wheelbase until '73. Am I missing something??
Old 01-19-2012, 03:18 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Don, different wheelbase only applies to long beds, cuz the short bed is the same 1965/72 (115").
8' bed: 1965/66: 129" wheelbase / 1967/72: 131" wheelbase.
Old 06-21-2012, 12:17 PM
johnski75's Avatar
johnski75
johnski75 is offline
72 and 73-79 shortbed wheelbase
Are the 73-79 shortbed wheelbases all the same? What is it?
Old 06-21-2012, 08:35 PM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
Originally Posted by 37 Ford guy
Old 06-22-2012, 03:26 AM
NumberDummy
Thru 1972, the inner frame rails behind the cab are 33 1/2" apart.
1973: Ford widened these rails to 37 1/2" on everything except 1973/77 F250 4WD's (High Boys) and F350's on the 140" wheelbase.
Old 06-22-2012, 10:22 AM
johnski75's Avatar
johnski75
Bill . . . you're the Man!
Too bad you can't bottle all of that information and sell it. You'd be a rich man (if you're not already).
Old 06-22-2012, 07:30 PM
garbz2's Avatar
garbz2
garbz2 is offline
Sheet metal mounting points are the same for the cab, and radiator support. Bed will need a possible re drill for mounting.
The frame profile and cab mounts are slightly different as they use differing cab insulators and radiator support pucks.
Garbz
Old 06-02-2021, 09:58 PM
JadenG19's Avatar
JadenG19
JadenG19 is offline
Garbz
How difficult are these modifications??
Old 06-03-2021, 11:36 AM
TA455HO's Avatar
TA455HO
TA455HO is online now
Unfortunately, Dave has since passed away. See the thread from NumberDummy below. As the thread mentions Dave was a master fabricator. Posts of his showing some of his work left no doubt he was a talented individual.
in memoriam - Ford Truck Enthusiasts Forums (ford-trucks.com)
Old 04-17-2023, 12:04 PM
spchallenger340's Avatar
spchallenger340
spchallenger340 is offline
6th Gear
I found out they only make a S/S brake line kit for a 1966 Ford F-100 and F-150 and I have a 1966 F-250 3/4 ton 2wd with the D81 long bed body .. will the F-100 F-150 long bed brake line kit work for me ?? any help would be greatly appreciated on this matter .. Thanks
Old 04-17-2023, 03:31 PM
NumberDummy
I heard that Tom passed away awhile back, and that his wife is disposing of all the parts.
Quick Reply: 1965-72 f100 shortbed frames the same?
