1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
06 Expedition stalling at stop signs
Old 01-18-2012, 01:28 PM
06expeiditionMan's Avatar
06expeiditionMan
06expeiditionMan is offline
Angry 06 Expedition stalling at stop signs
First all good forum. i own a 2006 Ford Expedition limited 5.4L. About 2 weeks ago i was on my way home I was at a stop Sign and the engine just stopped running. so i started it back up and it started. a couple day's later i was driving around and again it stalled out, it took me 30 mins to restart and it sounded like it wasn't getting fuel. so i changed my air filter, and fuel Filter. I took it for a drive it went good for 9 miles and on my way home again it stalled out. also i changed the TPS on the thing. Anyone can help me out or what. i'm doing the Dealer thing at the end of the month so i would like to know what might be wrong. thanks in advance
Old 01-20-2012, 12:50 AM
alloro's Avatar
alloro
alloro is online now
Received 4,199 Likes on 2,434 Posts
Your first step in diagnosing this is to do a fuel pressure test. Your pump could be starting to go and the engine is basically losing it's fuel flow. If this only happens when you have less than 1/2 a tank of fuel then it is 99.99% likely a bad fuel pump.
Old 01-24-2012, 08:49 PM
Flash Jorden's Avatar
Flash Jorden
Flash Jorden is offline
I had a similar problem. It was accompanied by a "trumpeting" sound coming from the air filter/intake area. Turned out to be the Idle Air Control (IAC) valve. I replaced it and that solved my stalling/cutoff problem. However be warned. I first replaced it with an aftermarket one from Autozone (my favorite auto part store). That stopped the stalling, but it moved the problem to the other direction. Now the truck started surging forward, and you had to step hard on the brake. I immediately removed that one, returned it, and went directly to my local dealer. They asked for my VIN number to get the right one. It cost more of course. I put that one on, and she now runs like brand new. The IAC doesn't kick a Check Engine Light code when bad, or at least not one directly pointing to it.
Hope that helps,
-Jorden
Old 01-16-2013, 02:30 PM
06expeiditionMan
Figured it out
OK $6,000 later... changed the Catalitc converters shot! $3,500, Camshaft Play exsesive shot motor! replaced the motor.. still had the grinding noise when starting.. Flex Plate, Starter SHOT!! so now all change what i have left a bill from hell and a new engine, starter, flex plate. was not fun going though all this hell.
Old 01-16-2013, 02:41 PM
dlibson's Avatar
dlibson
dlibson is offline
Sounds like you were had...
Old 01-16-2013, 02:53 PM
06expeiditionMan
HAD and then Hung out to Dry and then left in the ocean to float away.
Old 01-16-2013, 02:57 PM
dlibson's Avatar
dlibson
dlibson is offline
Yeah, I'd put money on you didn't need any motor work. Cats, sure. Common, although you can get that done cheaper...
Old 01-16-2013, 03:09 PM
06expeiditionMan
well here in the GREAT? state of California.. only dealers can install CAT's.
Old 01-16-2013, 05:58 PM
alloro's Avatar
alloro
Surely you jest!
Old 01-16-2013, 06:19 PM
lv2race's Avatar
lv2race
lv2race is offline
Yes, only dealers can install cats (hence the 49 state legal cat) but I believe emission equipment is warranted for 8 years and 80K. If you are below that you should look into it. The link is dated, but it sounds like someone owes you some $$$.
http://www.epa.gov/otaq//consumer/warr95fs.txt
Old 01-17-2013, 01:10 AM
ZakMay09's Avatar
ZakMay09
ZakMay09 is offline
Your problem sounded like one I had around 75k. I had a hole is the PCV hose leading into the respective valve on the engine. Basically, I was leaking air into the engine causing it to stall every time I came to a complete stop. Cheap fix and is still running today (3 years and 40k later).
TCA_Bowhunter
1997 - 2003 F150
12-13-2009 06:05 PM
denangme
09-23-2005 09:46 AM
Roland Donnell
Texas Chapter
11-16-2004 11:08 AM
Roland Donnell
Modular V8 (4.6L, 5.4L)
11-14-2004 10:13 AM
tommyzax
1999 to 2016 Super Duty
06-17-2003 01:44 PM
Quick Reply: 06 Expedition stalling at stop signs
