Newbie to this forum
Old 01-16-2012, 04:56 PM
coastie72's Avatar
coastie72
coastie72 is offline
I am an ex Ford Parts Manager, put out of work after my former owner sold his dealership. I worked for the original dealer for 35 years 8 months. Started in the warehouse and worked my way up. Lasted 7 months with the new owner, just long enough for them to get THEIR computer system in place and I was the last of the original managers to be terminated.
I always wanted this body style F-150, so I finally found one I could afford, being still unemployed.
I am glad to be a part of this forum, I have been on many others in the past.
Don
Old 01-16-2012, 05:05 PM
Grubbworm's Avatar
Grubbworm
Grubbworm is offline
Sorry to hear about your lack of employment. But, welcome to the site anyway. This is an excellent forum.
Old 01-16-2012, 05:19 PM
96 Ford Flareside's Avatar
96 Ford Flareside
96 Ford Flareside is offline
Welcome, lots of good info on this site, nice looking truck too.
Old 01-16-2012, 05:22 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
Glad to have another expert ford parts guy here.
Hope you frequent this forum often to share your knowledge with us.
Keep reading and I'm sure you'll find lots of useful info and be a great help to others.
Old 01-16-2012, 05:30 PM
Shepdawggydawg50's Avatar
Shepdawggydawg50
Shepdawggydawg50 is offline
tail lights out
I have a 93 f350 xl . Signals works. flashers work. Head lamps work. Parks work. brake lights work. Just no tail lamps or reverse lamps. Changed all pernate fuses. However i lookd undet the hood and all powr distributor fuses good i just dont know about thse that i cant see fuseable links. What ta do?
Old 01-16-2012, 06:11 PM
coastie72's Avatar
coastie72
Just an educated guess, but ALL light wiring feeds through the multi-function or as some may call it, turn signal switch. Could not say for 100% but that may very well be the problem.
Old 01-16-2012, 06:36 PM
Edgethis's Avatar
Edgethis
Edgethis is online now
Welcome to the forum. Always glad to see a new Ford truck owner.
Old 01-16-2012, 06:54 PM
danr1's Avatar
danr1
danr1 is offline
Turn/hazard/stop lights do go through multi-function switch, tail/lic and backup lights do not.
Backup lights feed direct from trans depending on which one you have uses either MLPS or NSS (auto or manual).
Tail lights are direct off of the main light switch, front markers work based on what you stated? if so shows that circuit is working, problem is likely up in front of rear bumper.
Tails and lic plate light powered via brown wire, check for breaks in that wire perhaps where someone hacked in trailer lighting. Unplug tail light harness from main harness, test for power at brown wire at the main harness verify its to that point.
Reverse lights, feed by fuse E engine compartment f/b.
They are feed by a black-pink wire, same as above check for hacked in trailer lighting in front of rear bumper, that is more often then not reason for rear lighting problems.
Some guys cut the wires to tap in wrap with black tape, just doesn't last.
Old 01-16-2012, 07:52 PM
deljac's Avatar
deljac
deljac is offline
welcome to the site, sorry to hear about the job.
Old 01-16-2012, 08:20 PM
Scooter70's Avatar
Scooter70
Scooter70 is offline
Welcome,great site.I haven't been here long. I do have fun here tho. Sorry about your job.
Old 01-16-2012, 08:32 PM
Roger T. Pipe's Avatar
Roger T. Pipe
Roger T. Pipe is offline
Hey There, welcome to the site...the job story stinks, but hopefully you'll find something out there that you enjoy doing!
Probably the best thing that ever happened to me in my career was to get laid off after almost 20 years in the industry (movie business). It truly gave me the opportunity to find work that I actually like. Best of luck to you-you'll get thru it, I promise!
This forum has a LOT of good people, much more good than bad, it has its know-it-all's, they'll always think they're right so ignore them. It's got members with sage wisdom and great advice-make sure to give them the rep points they deserve. Lastly, it is always good to have a new, knowledgeable member on board, so again-welcome!
Roger
Old 01-16-2012, 09:27 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
But... i'm always right... oh, and welcome to the site!.
Bob_91SC4x4
03-17-2012 09:53 PM
Rustynut
24
09-02-2011 10:30 PM
DPigg49
04-08-2010 01:29 AM
cakelly70
1997-2006 Expedition & Navigator
05-12-2007 02:47 PM
Kamikazee
1999 to 2016 Super Duty
03-29-2002 10:06 PM
Quick Reply: Newbie to this forum
