CCV Oil Catch Can
CCV Oil Catch Can
I wanted something a little cleaner looking than a PVC pipe to use as an oil catch can for my CCV mod. So I did some googling and found that the infinity guys were using air compressor water filter. So I thought We could use it too.
So I went to Home Depot and Lowe's and found that those filters were just too small (this is my opinion). While I was at Harbor Freight I found one that was bigger.
Then take it all apart and throw away the filter.
I thought the valve on the bottom was a screw type drain ****, but it turns out it was a valve that is actuated on pressure. So when the bulb pumps up to like 10 psi the valve seats and when it depresses it drains. So I have to drill it out since it was pressed in.
This was a pain in the *** to get off!
Then I bought the kind of valve I wanted but the plastic was not threaded. So I had to thread it, but i didn't have the right pipe tap. So I just threaded with with what I had and then slowly worked the valve in. It's not coming out. I also tested it for leaks.
Then I put the pot scrubber in the catch can to help catch any oil coming out. This will make it super easy to drain.
I wanted this to look good so I painted it Ford Red.
It should be noted that I had to sure 3/4" hose from the valve cover the to catch can, and 5/8" out of the catch can. The reason for this is because I could only find 1 x 3/4" barb fitting. This explains the 2 different fittings.
Here's how I routed the hose.
Then I used a universal rubber strap type exhaust hanger to mount the can on the outside of the frame rail.
I tried my best to show how I routed the hose. Also, I got my nice paint job dirty and smudged. I probably should have let it dry longer.
Also, I put in my new 6637 air filter from Riffraff. I can really hear that turbo spool up now. Its awesome!!!
I tried to get as many pics as I could to let yall know what I did. If you want more pics let me know. Also, if i botched this job, let me know before I really break something!!!!
Thanks,
Dave
Thanks,
Dave
Looks real nice...
Is the pot scubber just insurance to keep any collected oil from sloshing back into the lines?
Can someone chime in with how many miles it takes to get a third of their catch can full with oil?
The reason for the questions is that I did the CCV mod yesterday and have no catch can at this time...I just routed the hose same as you and hooked it behind one of the running board mounts with the hose turned inward and down and stuck a vented cap on the end to keep stuff out of the hose but let the gases out...I drove it today with no smoke or smells bothering me...but, it will let any oil in the hose drip out and depending on how much that is, I may want to do something like you. I don't drive it that much and it probably won't be an issue but I'd still like to know...
I'll have to take a look at your set up on Saturday. You're gonna change your LPOP, right?
I'll let you know how much oil I collect after about a week or so.
Yep, I couldn't find anything handy except for an old chrome lug nut that would fit in the end of the factory hose and used a screw clamp to hold it securely....then, on my next trip to the parts house, I asked my cousin who works there if he knew of anything they had that I could use to cover the vent tube and he directed me to a 2 pack of rubber caps designed for covering deleted heater hose connections...although it fit tight, I put a screw clamp on it just to be sure...nice and neat.
I used a 3/4" heater hose plug as well... just don't tighten the clamp too hard. I did on mine and after less than a year, the cap cracked and dusted the intake a little... it was only 4000 miles, though, because it wasn't that way when I changed the air filter 4K before. I used a zip tie on this one so we'll see how this one holds up. I'm going to have to make myself a catch can just because I'm getting the rear of my truck "sprinkled" with oil drops. Not bad, but if I can catch it, why not? The smell does bug me, but my intake is dry as can be. With not being able to afford new boots and everything, the clean engine and plumbing is worth putting up with the smell IMO.
