Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southwest Region > Oklahoma Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Oklahoma Chapter Join Chapter, Leader: Gary Lewis
  #1 (permalink)
Old 01-15-2012, 04:24 PM
ncfirefighter46's Avatar
ncfirefighter46 ncfirefighter46 is offline
Garage is empty, add now
ncfirefighter46 is starting off with a positive reputation.
01 with a check engine light on
well my 01 i just bought has got a check engine light they say the bank 2 is lean ? i really dont know what bank 2 really means is it the left or right side? some people in the fourms say my intake is leaking. i thought it would be a O2 sensor, but the parts store just gave me a list what could be wrong, but if it is the intake would it not give a me a bank 1 and 2 lean not just one side, i dont know i have not messed with fuel injected engines before. the ones i have owned in the the past if the light came on and stayed on i would just sell it dirt cheap and buy something else LOL.
all this electrical stuff and computerized stuff is intimidating
__________________
73 ford ranchero gt (rebuild stage)
Will the last american > PLEASE grab the Flag
  #2 (permalink)
Old 01-15-2012, 09:07 PM
DRRXR's Avatar
DRRXR DRRXR is offline
GateKeeper
2012 Ford F-350
My Garage
DRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputation
Standing in front of the truck bank two is right or driver side. So here is the checklist
Easy checks first
Check your vacuum lines for leaks
If you cant find one near the pcv then keep looking. Normally a vacuum line leak will cause both banks to get lean fuel codes.
But check anyhow
Then check the MAF sensor for filth and clean it.
Then check your fuel pressure
Make sure the air filter is clean.
I have used some carb cleaner to spray around the and can sense a eng change when the rich fuel enters at the leak point.
If you have a good scanner you can measure voltage of the O2 sensor and spray a little carb cleaner into the the intake via a small hose or other entry point. Both O2 sensors should read upscale the one that does not is the bad one.
Hope its a vacuum leak. My daughters did this yesterday after a cold spell but she had both bank DTC's it was a vacuum line.
__________________
Rock
Tags
engine, ford, forums, lights, online, stay, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
