Boost Fooler 7.3
I have the Riffraff OCR overboost code regulator and highly recommend it. Very easy install. Just remove the hose to the MAP sensor, mount MAP sensor on OCR and install OCR. See HERE.
i bought this thing off of Ebay for $7 bucks. Th PO is 1057020 its a piece of wire that grounds out the ses code but i dont think it does anything about the defueling thats what i want. Sould've gone with Riffraff, the sure thing thats what you get when you try to go cheap.
Thanks for the responce.
Browsing the BD website, is doesn't look like they have a product for the 7.3....they have something called Boost Builder for the 6.0 liter. The connector looks the same though. Here are some links that might help you out.
BD Power - Product: Electronic Boost Builders
http://www.dieselperformance.com/pro...t_Builder1.pdf
Does your part look like the one on their website? If not, maybe you can give them a call and they might be able to e-mail you some instructions.
How does it block the SES light? If it lies to the PCM then it would accomplish the same thing since any defueling strategy would reside in the PCM calibration.
robjs111
07-29-2008 04:26 PM
