ECC Swap compatability? OD Light Blinking...
Old 01-06-2012, 05:35 PM
rlwilson2's Avatar
rlwilson2
rlwilson2 is offline
My buddy came over yesterday with his 94 f150 5.0 MT 4x4. We did some work on the front end went to pull codes and figured out the ECC was bad. Today we swapped with an ECC we where told would be compatible the engine started up and ran great but when we went to drive the truck the OD light flashed and was in limp mode. No prior transmission problems so I figure the problem is between the 2 ecc's can any one tell me if these 2 are incompatible.
Original
F4TF - AAA
Swapped
F4TF - BBA
Old 01-06-2012, 05:40 PM
rlwilson2's Avatar
rlwilson2
It is a Automatic not MT sorry..
Old 01-07-2012, 07:23 AM
subford's Avatar
subford
subford is offline
They are incompatible.
The F4TF - AAA (HOG0) is for a E4OD Transmission .
The F4TF - BBA (BUG0) is for a 4R70W Transmission.
Old 01-07-2012, 08:30 AM
rlwilson2's Avatar
rlwilson2
Is there a refrance avalible for this?
Old 01-07-2012, 09:28 AM
subford's Avatar
subford
subford is offline
Here is one but they do not list the BBA (BUG0) computer.
Fuel Injection Technical Library » EEC Program Codes
Old 01-07-2012, 10:24 AM
Conanski's Avatar
Conanski
Conanski is offline
What lead you to that conclusion?
Old 01-07-2012, 10:33 AM
rlwilson2's Avatar
rlwilson2
Sub thanks!
Con.. Ecc was in fail safe mode. Solid light. The truck has been doing very weird stuff. finaly would not run at all. Runs great with new ecc just will not drive!
Old 12-31-2012, 10:04 AM
Shawn conard's Avatar
Shawn conard
Shawn conard is offline
ecc swap
What other ecc can be used on a 1990 ford f250 5.0 e40d?
Old 12-31-2012, 10:07 AM
Shawn conard
What vehicle ford truck or bronco can take out the ecc which would work on my 90 f250 4x4 5.0 e40d truck?
Old 12-31-2012, 10:10 AM
Shawn conard
What other year of truck or bronco can I swap ecc to work with 90 f250 5.0 e40d?
Old 12-31-2012, 11:37 AM
Lead Head's Avatar
Lead Head
Lead Head is offline
Asking 3 times is not going to help you.
Is this a MAF (big sensor on the air box before the intake) or a speed-density truck?
Old 12-31-2012, 11:40 AM
Shawn conard
No speed denisty
Jaime74656
03-10-2015 03:29 PM
dyner
1997 - 2003 F150
11-17-2013 08:09 AM
djf36
04-27-2012 07:00 AM
Navistar444
01-16-2005 10:58 PM
dnmyoda
21
03-04-2004 08:34 PM
Quick Reply: ECC Swap compatability? OD Light Blinking...
