My F350 Brake Booster Upgrade from a '78 F250 4x4 C6 (already power brakes)
on
I upgraded my F250 booster to F350 Booster & Master cyl. today. My Booster was leaking so I decided to change it out with a F350 system. Ordered a reman Booster/Master combo for a '78 F350 460 auto w/o cruise from O'kragen's @ $107.99 before taxes.
Cardone Remanufactured 50-3311 - Loaded Power Brake Booster | O'Reilly Auto Parts
Everything just bolted up to my existing brackets. Brake lines needed to be cut, flared and have the correct ends put on; 1/4in for the front brake (large) reservoir and 5/16in for the rear. Don't forget to unplug your brake light switch or your lights will be on throughout the project.
Click on images to enlarge....
Here's a link to all the pics: Project images
Before:
During: Block to remove/install pin.
After:
And if you did it right you donate:
I wonder why it didn't hold vacuum:
Before:
After:
on
I'm still laughing as I type.... Good way to start the day, Thank you! You are correct! It didn't make much difference except my truck is running much better without a huge vacuum leak.... I was going to update this thread this morning with that info now it's done
I'm thinking that for a drum brake system it would increase braking power. Thoughts?
I put the set up on my slick and the first time I hit the breaks....woohoo
Mobile Photobucket
firegod33
04-04-2019 02:04 PM
fordguy76
05-18-2018 08:37 AM
Rusty_Old_F250
Ford Truck Parts for Sale
02-07-2015 07:07 PM
GeneStoner
16
02-09-2003 11:39 AM
