1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Is the F150 Stereo the same size / fitment as an F250 ?
Old 01-05-2012, 07:24 AM
zimsoundz's Avatar
zimsoundz
zimsoundz is offline
Afternoon,
I have a 2004 with oem cd player. I wish to fit a Becker head unit that i already have (sat nav, bluetooth in it already). But it is only single din.
So. What i want to know is, will a double din facia unit designed for an F150 fit my F250 ? (I can't get one labelled as F250).
F150 2004 - 2006
CT23FD06 Double DIN Facia Plate for Ford F150
F150 2006
CT24FD25 Facia Plate for Ford F150 2006> / Mustang 2005-2006
Don't worry about wiring, i haven't taken it out yet, but could somebody tell me / show me a picture of what plugs are behind there i can order (or make) the appropiate wiring adaptor.
Thank you
Gordon
Old 01-05-2012, 06:30 PM
dbass880's Avatar
dbass880
dbass880 is offline
Did you find anything out about your stereo? I have the same question.
Old 01-05-2012, 08:52 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
My thought would be that the radios for the 150 and 250 are interchangable for the 99 to 2004 so I would think the single din adaptor would be to. Maybe somebody that has done it will come along and give us a definate anwser....
Old 01-05-2012, 09:13 PM
dbass880's Avatar
dbass880
dbass880 is offline
I think you are right. Thanks.
Old 01-06-2012, 12:35 AM
zimsoundz's Avatar
zimsoundz
I've hunted through US ebay and it seems that the earlier than 2004 F150 is the same as the 2004 superduty.
i.e. eBay - The UK's Online Marketplace
The wiring harness i've found (well i think!) to an explorer, (escort and cougar which we get here easily) for only a few £.
G
Old 01-06-2012, 01:19 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
2004-2008 F150 has a different radio from the 99-2004 Superduty/F-150
99-2003 F-150 radio is the same one that your truck has
Old 01-06-2012, 01:35 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
The stock radio is known as a 1.5 din and not a true 2 din. Neither of the links you posted above will work.
Metra Part # 95-5817 | Ford Mercury Dash kit | Lincoln Dash kit | Metra Online
Metra Part # 70-1771 | Ford wire harness | Metra Online
those are the parts you need. You will also need to trim the factory plastic mount to fit a 2 din unit, use a dremel.
Old 01-06-2012, 01:37 AM
ford390gashog
Wait? I re read your post are you trying to fit a single din?
if so you need this one
Metra Part # 99-5804 | Ford Dash kit | Lincoln Dash kit | Metra Online
Old 01-06-2012, 09:38 AM
zimsoundz's Avatar
zimsoundz
Thanks for the replies. I'll order a 1.5 din adaptor plate.
Tylus, not sure if you've seen the thread about backup cameras you posted in some time. I replied in that a few days ago with a couple questions if you don't mind
Gordon
barnettbill
03-29-2014 06:38 PM
hank89
10-25-2007 11:21 AM
Chris_in_Texas
10-03-2005 01:22 AM
buymore
04-03-2004 07:55 PM
Quick Reply: Is the F150 Stereo the same size / fitment as an F250 ?
