View Poll Results: Do you use Fuel Additive in your 6.7 Powerstroke?
I use a fuel additive in every tank!
72
71.29%
Sometimes I use a fuel additive.
20
19.80%
I DO NOT use a fuel additive.
8.91%
Voters: 101. You may not vote on this poll
Fuel Additives for Diesel Bought in USA-Yes or No
Old 05-12-2013, 02:46 PM
ISurvivedNMU's Avatar
ISurvivedNMU
ISurvivedNMU is offline
2011-14 6.7 Powerstroke only. I would like to see a snapshot of additive users versus non-additive users.
Also, if you can, let us know what fuel stations you fill up at and if you use the same one all the time.
On both my TDI and Powerstokes I have always used Optilube (TDI Club group buy) since day one. I also try to fill up at Flying J or any truck stop.
Thanks for your info!
Old 05-12-2013, 03:06 PM
kper05's Avatar
kper05
kper05 is offline
I use Motorcraft PM-22-A.
There is almost always Shell diesel in my tank.
If I'm in town and need to fill the tank, I use the same station that has yielded the cleanest filters at 15,000 miles (30,000 miles total).
I may however top off my tank at a closer Shell station if needed but I can count the number of times I do that on one hand in a year.
Old 05-12-2013, 03:17 PM
DDLYSGT's Avatar
DDLYSGT
DDLYSGT is offline
I use standyne got treatment and ConocoPhillips truck stop for fuel,high turnover
Old 05-12-2013, 04:53 PM
djousma's Avatar
djousma
djousma is offline
stanadyne performance formula in every tank
Old 05-12-2013, 07:52 PM
Wrighton's Avatar
Wrighton
Wrighton is offline
Use Motorcraft PM 22 every tank.
Old 05-12-2013, 08:15 PM
Javi1's Avatar
Javi1
Javi1 is offline
PM-22-A in every tank
Flying J / Pilot or any larger truck stop...
Old 05-12-2013, 09:35 PM
Grout-Scout's Avatar
Grout-Scout
Grout-Scout is offline
Never put a drop of additive in my Cummins that had 150k on it when i sold it and I won't put it in this new 6.7 either. If Ford can't make a motor that can't handle regular diesel then I've bought my last Ford. I think most of these guys are "chicken littles".
Oh and always get diesel at either Murphy (Walmarts) or Valero.
Old 05-12-2013, 11:44 PM
Chad149's Avatar
Chad149
Chad149 is offline
I have not been at this point. I may once I get closer to the 100k. If something in the pump was not machined quite right my theory is not to help limp it along, let it fail under warranty.
Old 05-13-2013, 12:29 AM
mrjc's Avatar
mrjc
mrjc is offline
Stanadyne Lubricity + performance formula 50/50 mix. Loaf and jug on the corner. Kum and go next door has diesel cheaper but the last place I will go to get quality dry fuel is a place called Kum and Go.
Old 05-13-2013, 01:11 AM
WildWildWest's Avatar
WildWildWest
WildWildWest is offline
PM 22 A in every tank. In Western Canada. Use Co-op fuel 90% of the time. When I travel in the USA I use major truck stops but not too picky on which one. Flying J, etc.
Old 05-13-2013, 10:47 AM
my_crib_too's Avatar
my_crib_too
my_crib_too is offline
Received 1,183 Likes on 364 Posts
PM-22-A in every tank. That makes me a chicken little...
Old 05-13-2013, 10:55 AM
tolliewolly's Avatar
tolliewolly
tolliewolly is offline
I buy BP diesel. Has additives already in it. Every once in a while I add ford powerstroke additive to it.
Old 05-13-2013, 11:50 AM
johndeerefarmer's Avatar
johndeerefarmer
johndeerefarmer is offline
I use Power Service Diesel Kleen with cetane boost in every tank. Also use Walmart diesel.
John Deere tractors get Power Service about two or three times a year
Old 05-13-2013, 02:38 PM
RobFlag's Avatar
RobFlag
RobFlag is offline
Count me in the PM-22 every tank camp. My understanding is that in addition to increasing the lubricity, you also get a small (1 ish) MPG increase with the additive. Buying it by the gallon like I do, that means it's basically free so why wouldn't you use it?
Old 05-13-2013, 03:13 PM
tolliewolly
Where do u get it at?
Quick Reply: Fuel Additives for Diesel Bought in USA-Yes or No
