2001 f150 5.4 heater problem
no heat out of truck.
intake heater core hose gets hot, out doesnt but flushed heater core so no restrictions with flow
replaced thermostat already
cant find heater control valve even though they sell one at parts store and internet has conflicting reports that it is replaced by the blend door
any help would be appreciated
there is an electric motor under the radio above the transmission hump. It operates a small door inside the air duct that mixes outside air and heater core air to get the temp you want. First thing to do is pull the **** off the dash lever and see if the **** is tight on the shaft, or slipping. If it is turning, lay on the driver side floor and look up toward the radio. That is the motor. Take the plastic panel below the radio and above the hump off and look at what moves while you stroke the contnroll **** from hot to cold. Can be motor, small gear box, or cam level tied to the door.
BillJohnson
03-16-2016 12:32 AM
cigarxtc
01-19-2005 11:27 AM
