99 e250 trouble codes
Old 01-01-2012, 08:46 PM
wizzy214's Avatar
wizzy214
wizzy214 is offline
just bought a 99 e250 ext cargo van.
ran the obd2 and got these codes, can some one tell me what they are and how to fix?
thanks
P1406: Differential Pressure Feedback Electronic Sensor circuit Downstream Hose
p0442:Evaporative Emission Control System Leak Detected (small leak)
p0171
Old 01-02-2012, 09:00 AM
PStruwing's Avatar
PStruwing
PStruwing is offline
Check your vacuum hoses!
Old 06-16-2012, 04:52 AM
Adventure's Avatar
Adventure
Adventure is offline
Was your P1406 resolved?
The most common problem when getting a P1406 is the DPFE located on the drivers side of the engine.
But, I'm getting a P1406 and it's not caused by the DPFE so I was wondering if you might have found what was causing yours.
Old 06-16-2012, 11:38 PM
wizzy214's Avatar
wizzy214
wizzy214 is offline
yeah, i was a quart low on diff fluid. filled it back up and it cleared code.
Old 06-17-2012, 03:16 AM
critterf1's Avatar
critterf1
critterf1 is offline
That has nothing to do with it.
Old 06-21-2012, 05:00 AM
Adventure's Avatar
Adventure
I actually think it might be just what the code says, a plugged downstream line. There is an orifice in the Manifold to EGR Intake Tube Assy that allows a certain amount of exhaust gas to be vaccumed into the EGR assy. If that corrodes or gets plugged, you will throw a code since the differential pressure becomes too high on exhaust side. The nut / bolt at the exhaust manifold is pretty corroded. Looks like it will fall apart if I put a wrench on it. Can't find an online price for that tube (item 10 in some engine exploded views) so I just asked a parts person (my son) today for the pricing. I need the van to pull a trailer so I don't want to touch it unless I have a replacement available.
69ford99
1997 - 2003 F150
08-16-2013 12:18 AM
wildabeast
1997 - 2003 F150
05-27-2010 09:31 AM
edwardo
04-14-2008 04:54 PM
14psd
3.8 & 4.2L V6
01-26-2007 06:49 AM
Quick Reply: 99 e250 trouble codes
