Why old engines run hot
I'm stripping an 8BA I bought recently. I think it must have been run on river water its entire life. Something to think about if you are contemplating putting new plugs and oil in an engine that "ran when parked"... All this would be circulating in the cooling system. And this is just what I could pull out with a finger from the water pump holes.
YES YES YES!!
A LOT of old engines have a LOT of rust (and other debris if a marine engine) in the water jacket!
If they were run without anti-freeze for long the water jackets could also be fairly thin and risk being cracked etc. (so be careful using rust "remover")
Before I took my 292 to the machine shop, I removed all the block "core plugs" (mistakenly called "freeze" plugs) and thoroughly flushed out as much rust as I could! I even poked around in there with a piece of wire! (A LOT of rust came out!!)
Radiators will contribute to running hot for the same reason.......... because a LOT of that rust may have been pumped into the radiator clogging tubes AND if the radiator hasn't been cleaned EXTERNALLY........that is, pressure wash the bugs, and other debris out of the fins etc......You will not be able to move sufficient air through it!
Cheers,
Rick
Cheers,
Rick
Why Ross, whatever do you mean?! Surely you don't believe these old blocks are not as clean as a whistle inside.
The dirt rolled out when I removed the water pump on my latest project yesterday.
And the Sahara Desert rolled out of the water jacket when I spun the block around on the stand.
ShadowSnowLeopard
12-04-2012 12:26 PM
Broomfieldbum
10-06-2010 08:51 AM
HOILERAUTO
05-16-2008 09:09 AM
riley_boy
01-08-2003 07:59 AM
