what is this??????
well apparently i cannot post attachments so what it is, is a picture of a small black canister with 3/4 inch hose attached to it with an open end on the other side of it im not sure if it has anything to do with coolant or vaccum cause i had recently changed my thermostat and most likely overfilled my system and im thinking fluid came out of that because the thermostat area had no leak when we checked i think the clog had come out and just burst through that but im not sure
its on the passenger side between the battery and heater blower motor right above the vaccum canister i have a picture of it i can e-mail it or whatever.............. i think it would be alot easier if we could just post pictures on here...............
https://www.ford-trucks.com/forums/1...l#post10674174 Click on this link to see how to post pics.
You may not have authority yet because you haven't made 25+ posts. Once you make 25 you can add a signature and a few other things.
Your attachment is actually a link to a picture, then highlight it and click the pic button and it will just display the pic once you post Try that.
