Do u get a buleish smoke on start up after sitting over night? I do and also get a white smoke if it sits longer then 3 or 4 days. I think still have the orginal injector O rings and are going bad.
A way to test orings is get the truck up to full tempature and with the in park or neutral mash the go pedal to the floor the rpm's should climb up to 3k if the stumble around 2k and the shot up to 3k then o-rings are bad
Ya its a 96 F350 cclb 4x4 304,000 8" lift on 37's 3" dp all the way out the rest is stock waiting on my 6637. Not much but just starting. Ps its a cali truck.
