64 heater hose hook up
I'm installing a 360 in a 64 f100 4x4 I need to know which heater assembly hoses on the passenger side firewall go where on the motor the hoses on the motor go from the top of the water pump to a T one hose off of it isn't hooked to anything the other gos to the top fitting on the intake manifold then out the other side of that fitting into the carb spacer that has a coolant passage then the other side of the spacer has nothing hooked to it anyone help with how I should replumb this setup I'd appreciate it
One hose goes from the heater core to the pump and the other goes from the manifold to the heater core. Feel free to remove the waste of space heated carb spacer! I had one fail on me and hydrolock the engine. If the fitting in the manifold or the pump are rusted you can replace them with sections of hardware store iron pipe it works great and the heater hose makes a very secure connection once slid over the pipe.
Peeps are forgetting something, you're swapping in an FE engine. There is no provision in the intake manifold for a heater water valve.
1965/66 F100/350: Spliced into the inlet to heater core heater hose is either a manually operated shut-off valve (C5TZ-18495-A) or a cable controlled heater water valve (C3UZ-18495-A).
1967/72 F100/350: C3UZ-18495-A / 1973/76 F100/350: Vacuum controlled heater water valve, spliced into the inlet to heater core heater hose (D4AZ-18495-A).
Someone removed it, prolly because it was leaking, then spliced in the C3UZ-18495-A cable controlled heater water valve...that was not offered for F Series trucks until 1965.
Mr. Bill my 64 4x CC has a "fresh air heater" which has the cable operated valve on the right fender well. My 64 2x non CC has the valve mounted on the intake (even tho it's a swapped in 302). Wierd that it's listed on 65 and up, wonder...another old Ford mystery lol
Applications: 1963/67 E100 / 1965/66 F100/1100 / 1966/77 Bronco / 1967/72 F100/750 / 1969/74 E100/300.
harrythehack
11-29-2018 04:58 PM
DirtyTace
13
01-09-2008 01:05 PM
