My friend got a set of glass packs for his Chebby, and doesn't need the old muffler so he's giving it to me. It's a similar muffler but in better shape
No way.. the guy is my pal. last year he offered me the truck (300K miles with a reman longblock in the bed under a camper shell) but it'd be subject to emissions testing and I sure as heck ain't gonna go through that hell.
Got the cats in from a local FTE member. $30 for the two of them. Chiseled out the catalyst and slid a piece of pipe through. Just remembered that Grandma promised a check for good grades Maybe I'll get to do this sooner than later.
I just got my 79 back to the crappy setup for stock 79 400 California specs. Single cat and single exhaust. Before, I had a full dual system with Summit Racing cats and mufflers. The new setup seems to have higher low end torque, but seems doggy at higher RPM's. That could be due to the 6 deg timing required by CA. As soon as it passes the STRINGENT Calif. smog, I'll advance the timing. That will probably help the power. Bottom line....true dual exhaust on a 400 seems to reduce low end torque. I use mine mostly for snow plowing, so the low end is important to me. Probably due to a scavenging issue. Original 2V carb setup.
Interesting. What pipe size and exit location for the duals?
Welded the cats and sprayed some high heat primer.
