ScanGauge II
ScanGauge II
Wondering what those of you that are using ScanGauge II think about it. I'am mostly interested in the additional gauge readout capibility it has.
Happy Holidays and thank you all.
Tom
2003 F350 4x4 Lariat CCSB SRW, Autometer Z Series Gauges, 4"Diamond EyeTB, JWVB, 6.0Trans cooler, 6637, F5 DP Tuner, HPX, IH Bellowed Up-Pipes, Foil Delete, WW, Airlift Rear Bags, Zoodad, Recon LED Cab Lights, GPR-LED, 05 Mirrors
Tom
It works great. I usually watch ICP, IPR, EOT and either voltage or average fuel mileage.
I know the following work. I cant recall what were stock are what are X-gauges. ICP, IPR DC, Oil temp, coolant temp, trans temp, Intake air temp, GP's on-off, Exhaust back pressure, MAP, boost, Volts, RPM, and MPH. As long as you stay on one tune the fuel mileage stuff is very accurate. I have not been able to get it read codes.
As far as I know, the terminator gauge will pull some codes, data log, and view PSD specific PID's
Terminator Engineering
Scanguage II from Linear Logic pulls info from the PCM. Plugs into the OBD port... Does DTCs, and works very well....
The Aeroforce Scangauge will do a lot of the same functions. In addition, it will allow you to do a buzz test of the injectors (IIRC).....
I use the Scangauge II for monitoring EOT, ICP, IPR Duty Cycle; and ECT and Voltage (switch back and forth on that one...)
