Suggestions on front metal assembly on 52 PU
I personally prefer to paint the mating surfaces of the parts, assemble and adjust to fit and then paint the overall vehicle. With our old trucks there are many body seams you can tape off and paint single areas one at a time. You avoid the possibility of scratching parts while installing. If you do you still have the parts in primer which is a lot easier to repair than top coat paint.
We considered both ways and decided to assemble it piece by piece. It was easy to get everything lined up without damaging the paint. I thought maybe the fiberglass fenders would flex to much and crack the paint if all of it was together. Good luck either way you use. We started with the grille first. .
Either of the suggested ways is practical. However, if it were me, I'd probably edge all of the body panels like Bob describes, assemble/fit/adjust them and then paint the whole assembly. I'd be afraid of scratching them during assembly if everything was painted separately. Plus, when you paint all at once, texture, color and coverage is the same.
Think that is the best approach, paint the edges, assemble piece by piece, paint the grill, poss grill backing and then after assembled, paint the cab & front end as a unit. How about fender whelts, any ideas on these? I was thinking of blasting the bottom of the cab, priming and add good quality of undercoat on the bottom. Engine, trans & radiator is in place now.
Bill
Bill
Personally, I think fender welting looks out of place on our trucks. It was never there originally. On older cars where it does belong, we always installed the fenders loosely then slipped the welting in the gap (cut U slots in the welting flange to fit around the bolt) and tightened and adjusted as we went.
