still screaming at idle
i have posted this issue before, but id like to go back to square one. in the morning my truck idles at around 3500 rpm. sometimes it will do it for about 10 minutes, sometimes it wont stop at all. i feel like the truck is going to blow up at red lights. its almost dangerous to drive since the truck fights the brakes. heres whats new:
-cap, rotor, wires, plugs
-tps
-iac
-egr sensor
-coil
-pcv valve
-intake gasket
-pretty much every vacuum line.
-all the grounds have been tested and contacts cleaned
i have never replaced the map sensor, coolant temp sensor, the egr valve itself, or the egr valve solenoid. the only codes i get are some egr codes here and there, but i dont think anything egr related could cause my problem, however the truck does buck violently at low rpms sometimes, so i think i should replace the valve anyway. sorry for the long post. all help is appreciated.
-tps
-iac
-egr sensor
-coil
-pcv valve
-intake gasket
EVR vents vacuum from atmosphere when not directed to EGR controling it, might be broke/wide open at times and then to add to the problem when its not supposed to be.
Have EGR issues might want look into that, EGR issue might all stem from be to low engine vac left over due to leak/s pull it open?
Unplugging IAC would show if it has any control over/effect of engine speed or not and or if its part of or all the problem. "New" unfortunately doesn't always mean "good" either, a problem in of itself!
jwillard
15
04-01-2012 10:07 PM
broncobillc
13
08-20-2004 08:13 PM
bigdaddyjdp
02-10-2003 04:48 AM
