Increase compression ratio a little?
How dramatic will a 0.5 increase in my compression ratio make? Is that enough to notice anything?
I ask because I can get one head gasket vs. another and it would make my compression ration increase from 9.27:1 to 9.55:1, OK, so a difference of 0.28.
It's a performance engine and will eventually be supercharged. Vortech told me I should try and stay close to the stock compression ratio, 9.0:1. So I am not sure if my increase to 9.55:1 will do me more damage?
Thanks.
Thanks.
Assuming you're running a centrifugal SC (since you mentioned Vortech), and assuming you went with a forged rotating assembly, I would go the 9.55:1 route. Centrifugal SC's and turbochargers generally tolerate higher CR's than PD blowers, and the higher CR's keep them from being total slouches when you're cruising along out of boost.
It will also depend on your heads. Will you have factory iron or aftermarket aluminum heads? What is the chamber design? What form of spark & fuel management will you have, what camshaft profile, how much boost, . Either way, .28 points is not a huge difference, so I would probably just look at the head gasket design itself and go with the one that will be the most durable under boost and let the compression chips fall where they may.....it can be tuned accordingly.
Thanks.
Thanks.
Were you able to determine if the bearing's got wet?
cujo8
05-01-2006 10:18 PM
smp2c
09-13-2003 07:33 PM
jeff moon
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
02-03-2003 07:00 AM
