Will this steering shaft work?
Old 12-15-2011, 12:15 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
ManfredVonRichtofen is offline
Borgeson Universal 000975 - Borgeson Universal Telescoping Steering Shafts - Overview - SummitRacing.com
I need a new steering shaft since my old one is worn out. The rag joint and the u-joint on it has gave out.
This new one has double u-joints so I won't have to worry about a rag joint.
Anyone use this one before?
Old 12-15-2011, 12:44 PM
OldStyle's Avatar
OldStyle
OldStyle is offline
Rusty Roller
I would measure yours and call them to be sure it is the correct length for your application. Even though it telescopes you should get the overall length and compressed length.
Old 12-15-2011, 01:06 PM
ManfredVonRichtofen
I just ordered it, Bronco Graveyard has the same one.
Ordered it from Summit since it would get here in a day. So maybe I get it tomorrow.
Old 12-15-2011, 03:24 PM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Moderator & parts seller
Received 3,290 Likes on 2,446 Posts
That shaft will work great, I got one to fix my sloppy steering 77.5 4x4 F250. I am pretty sure its a cut to fit/slip shaft universal deal.
The slip shaft design is old school crash protection idea, I think?
Just measure the total length (spline shaft to spline shaft) and cut the inner solid shaft first, them the outer hollow shaft has to be LONGER.
I measured mine like 5 times, it could be a $$ mistake.
Old 12-15-2011, 03:41 PM
ManfredVonRichtofen
It's a 3/4 36 spline shaft. It's got a vibration damper on it too.
Old 12-15-2011, 04:51 PM
77&79F250's Avatar
77&79F250
Ah really where is that at, I looked at the pic and do not see that? Are you talking about the rubber boot?
Old 12-15-2011, 05:07 PM
ManfredVonRichtofen
Its in the overview of it.
I guess is under the u joint (that big metal piece)
Old 12-15-2011, 05:59 PM
77&79F250's Avatar
77&79F250
Well still don't know about this damper thing, I know mine did not have anything like that ? But all that matters is it fits and fixes your trucks steering.
Old 12-15-2011, 06:00 PM
ManfredVonRichtofen
That's a big 10-4
Old 12-15-2011, 06:55 PM
helipirate's Avatar
helipirate
helipirate is offline
I have the same steering shaft with the vibration dampner. Its nice and fixed my U joints. You will have to cut it to fit though.
Old 12-15-2011, 07:26 PM
ManfredVonRichtofen
For real? How much?
Old 12-15-2011, 07:57 PM
helipirate's Avatar
helipirate
I cant remember how much I cut mine. I left it a little long for a body lift if I want one. Its not hard though, just one cut.
Old 12-15-2011, 08:56 PM
ManfredVonRichtofen
Well it should push it to make it smaller since it's a telescoping shaft
Old 12-15-2011, 09:28 PM
helipirate's Avatar
helipirate
Yes but the inner shaft arrives much longer then it needs to be, so long that even fully collapsed it will not fit. The instructions have you trim it to where it will have the maximum collapse distance, incase of an accident, while still fitting your application.
Thats how mine was at least. Mine is the same shaft but bought off ebay so maybe yours will come pre cut but I dont belive it will.
Old 12-15-2011, 09:29 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
The rag joint is for vibration and the isolated sleeve accounts for slight movement/shifting of the cab... it's also supposed to collapse in the event of a head-on collision so the steering wheel isn't plunged into your upper torso. Yeah, it would leave a mark - a really, really, really big mark.
IIRC, it was around 1968 or so when a collapsible steering column system became mandatory.
Quick Reply: Will this steering shaft work?
