casting /parts #? AKA hey parts dummy
While attempting to figure out my hard starting problem I figured I'd throw out the parts/casting numbers that I can see on my engine. I figure that if I'm using the wrong dwell,timing, plugs etc, due to not knowing what I'm working on it might add to the issue.
Block C6ME-A
Intake C5TE-8(or 9 can't tell )425-F
Heads C4TE-D
Exhaust manifold C6TE 9480C
N3
As always any help/knowledge is greatly appreciated, I can just see that something as simple as the wrong plug would make a big difference in starting.
Block C6ME-A
Heads C4TE-D
N3
Block C6ME-A
Heads C4TE-D
Exhaust manifold C6TE-9430-C
Block C6ME-A
Heads C4TE-D
C6ME-A is a 1966 casting number related to FE & FT engines. When the block was finished, it could be any of these: FT 330 2V Medium Duty, FE 352/390/410/428.
Measure the stroke, that'll pin it down...some.
C6TE-9430-C is an ID engineering number, not a casting number. It cross references to: C4TZ-9430-B Rams Horn Exhaust Manifold (right/left is the same) for 1964/72 FT engines.
I suspect the heads and intake manifold (possibly the block as well), are also from an FT engine, prolly a 330 2V Medium Duty, which shares some parts with FE engines.
"Squire" Don: Profile sez 1964 F100.
Picked the engine out of a junk yard a couple of years ago in a bind to get the truck back on the road. Started it while it was sitting on the ground,it ran and I couldn't pass on the price. The only info I could get from the people in the yard was "it was a big old truck" that the engine came out of, so the years isn't known to me.It had the right bellhousing to mate to the T-98 in my 64 F-250 4x so I snatched it up. The stroke is just under 4 inches by a fraction, it has an 8 qt oil pan and the dip stick is on the passenger side. Being as the engine is in the truck I can't measure the snout of the crank to determine if it has an FT crank. I have no idea if someone used a FE short block with their old head, .intake, etc. Were the same spark plugs used in FT heads as FE's ?
332: 1958/59 / 406: 1962/63 / 427 has a different casting number prefix.
atomicjoe23
08-11-2011 07:00 AM
Racemaster33
18
01-05-2007 11:18 AM
horseman54
11-01-2006 10:30 PM
stargazer
17
12-03-2002 06:11 PM
Ratsmoker
12-12-2001 04:52 PM
