FE Id
Old Oct 31, 2006 | 07:28 PM
horseman54's Avatar
horseman54
Question FE Id
I am trying to identify a FE engine that I recently obtained. It has the 58 352 cast in the left front corner but I can't find any other casting numbers on it where they should be. The intake is a 2V with cast number C9AE and the exhaust manifold has a number C8AE. Any ideas?
Old Oct 31, 2006 | 07:43 PM
Thomasm67's Avatar
Thomasm67
Do you know what it came out of?
Old Oct 31, 2006 | 09:48 PM
horseman54's Avatar
horseman54
No, I bought it and an automatic tranny at an auction.
Old Nov 1, 2006 | 12:46 AM
Bear 45/70's Avatar
Bear 45/70
Well the heads are 1969 or later and manifolds are 1968 and later.
Old Nov 1, 2006 | 07:38 AM
Sport45's Avatar
Sport45
Welcome to FTE!
If you'll measure the stroke length that would narrow it down some. Pull a spark plug and probe the cylinder with a piece of wooden dowel that will fit through the plug hole. Mark the dowel at the top and bottom of the stroke and measure how far the marks are apart. I don't know for sure if it helps on FE's, but you can also measure the deck height. That's the distance from the center of the crankshaft to the center of the head gasket.
Old Nov 1, 2006 | 10:30 PM
LedheadELH's Avatar
LedheadELH
and also, if you look between the 2nd, and 3rd spark plug, there should be number cast on the heads, should be something like "C8AE-H", or something similar, but w/ different letters/numbers. Let us know what it says.
