Water in fuel sensor.
Old 12-14-2011, 02:41 PM
dn29626's Avatar
dn29626
dn29626 is offline
If i remove the bowl heater and leave the harness connected to the bowl will the water in fuel sensor still work while eliminating the "bad heater, blown fuse, engine will not run" problem?
Old 12-14-2011, 02:52 PM
snakedoc's Avatar
snakedoc
snakedoc is offline
i dont know. all i have seen is them unpluged both.
Old 12-14-2011, 05:13 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Yes. That will work just fine.
Old 12-15-2011, 04:48 PM
dn29626's Avatar
dn29626
dn29626 is offline
Alternate thought.
Since i want to keep the water in fuel sensor working, will simply disconnecting the heater wire from the heater (inside the bowl) do the same thing? Keep the water sensor working without allowing a bad heater to kill the truck?
Teamrope
11-25-2015 07:14 AM
SARDiverDan
11-11-2014 04:28 PM
onelionhunter
02-21-2011 10:24 PM
TobiasR.
02-08-2011 02:12 PM
benthere
01-22-2011 01:06 PM
Quick Reply: Water in fuel sensor.
