Fuel Bowl Heater Delete/Keep WIF Sensor
Not sure how to title this but I think you get the idea. I have searched the forums and I can't find the thread that described how to remove the fuel bowl heater but keep it hooked up in a way so that the water in fuel sensor still works. I know I could just unplug it but I would like to keep the WIF function. I could just pull out the heating element and start cutting wires but I remember a thread some time ago that gave directions on doing this. Any help would be much appreciated.
Don't need a fuel bowl heater and one less weak link of shutting the truck down with a blown fuse. I know I could wait until if/when it happens and then unplug it, replace fuse and keep going but with my luck it will happen at the most inconvenient time so I would rather mess with it on my schedule
Thanks for the info. I knew I could remove the element from the inside but I was not sure if the system would still cause an issue by sending signals for a heater that was not in place. I think the main cause of the problem is when the element breaks on the inside and shorts out which trips the fuse. I need to change the filter soon so now would be a good time to get this taken care of while I have it drained.
onelionhunter
02-21-2011 10:24 PM
