Mating a later 3-speed to a y-block
Hey guys. I have a '61 F100 292 y-block with non-syncro'd 3-speed on the column.
I know of two other F100's that are a little newer (one is a '67 with a 300 and the other is a '68 with a 390) that have syncro'd 3-speeds with overdrive.
My question is, if I could find one of those could it be made to work with the y-block in my f100? If so, what would it take? Surely someone has done this before.
thanks
Michael
thanks
Michael
Originally Posted by Mikulh
...that have syncro'd 3 speeds with overdrive.
The Borg Warner T-85N 3 Speed Manual w/Overdrive was an option in 1965/71 F100's. It does not have 1st gear syncro, so it is not an all syncromesh transmission.
1961/64 F100's were available with the optional Borg Warner T-86 3 Speed Manual w/Overdrive. It's not an all syncromesh transmission either, only the following is:
Ford type 3.03 3 Speed Manual all Syncromesh Transmission (no O/D) introduced in 1963 F100/250's with 223's & 292's.
To install one a these, find a 1963 or 1964 F100 (preferably a 1963) that is similar to a 1961/62 F100, get the trans, linkage, driveshaft and other necessary parts from it.
This trans was used from 1963 thru 1987 in a gazillion applications, including Ford/Merc Passenger Cars, F100/350's (F350's after 1966), Bronco's and Econolines.
But only 1963/64 F100's will have all the correct parts to install one a these type 3.03's in a 1961/62.
My 1965 F100 had the T-85N. You either double clutch into 1st gear, or wait until you came to a dead stop. I prefered the "old timey" double clutch method.
O/D kicks in/out between 30-35 MPH
No such thing as a 3 speed manual all syncromesh transmission with Overdrive. If the above 3 speeds are all syncro, they do not have Overdrive.
Or does my transmission have them and they're just worn out?
It would be far cheaper (and waaay less labor intensive) to replace the two blocker rings, 3 syncro shoes, snap rings, gaskets, front/rear seals, than to swap trannies.
Besides, the used tranny you buy may not be any better than the original, could be a lot worse.
That is the approach I will take. I wasn't aware that mine was even supposed to have syncros.
How complicated is it to replace the parts in question and where would I get them?
Can I do it with basic hand tools or would I need access to a press?
I would purchase a shop manual if you do not have one, as it describes the procedure to replace them and has good reference drawings of the gears and how they relate.
Garbz
Daddyo's garage
12-16-2019 06:06 PM
